How will you reach the seat adjustments? How will the electrical connections match?
What will you do for the passenger side if you attempt the (unadvisable) switch?
Time for seat covers, or a used seat from a junkyard.
I checked the part numbers and found that the part numbers for all parts of the seat cushion (cover, pad, spring assembly, seat track, etc., etc.) are different between the right and left front seats.
Thanks. I knew it would be just too simple to do a switch. Is the leather seat surface the same same or different? I think the leather is attached to the frame with "hog rings". I have the heated seats.
