Front and Back windshield washer dead?
Old Mar 12, 2010 | 02:16 PM
chachacha's Avatar
chachacha
Unhappy Front and Back windshield washer dead?
My 99RX300 AWD: front and back washer suddenly stopped working… is the windshield washer fluid pump dead? Do they use the same pump or 2 separate pumps? Any fix? I wonder this is a pump replace situation or an electrical problem? Help!!!!
Many thanks my beloved CL members
Old Mar 12, 2010 | 03:51 PM
Nad1370's Avatar
Nad1370
Stupid question but, do you have fluid in it?
It only runs 1 pump.
If yes then I would check the 20amp washer fuse located behind the coin box inside the vehicle.
We'll go further in diagnosing if the fuse is ok.
Attached Thumbnails Front and Back windshield washer dead?-copy-of-imgp5214.jpg
Old Mar 22, 2010 | 04:24 PM
chachacha's Avatar
chachacha
fluid is full...fuse is ok..
Old Mar 22, 2010 | 06:10 PM
Nad1370's Avatar
Nad1370
Ok...
Check to see (hear) if the washer motor is running when the switch is turned on.
Location---Right front fender
Attached Thumbnails Front and Back windshield washer dead?-img_4268-copy.jpg
Old Mar 22, 2010 | 06:26 PM
Nad1370's Avatar
Nad1370
If you don't hear any humming.
Then your washer motor might be toast or a wiring problem.
First you have to get to the washer motor to check it.
Be sure to have a test light to check for power and ground(signal from the switch).
Pic 1 and 2---take out the 4 10mm screws/bolt, then fold fender liner out.
Pic 3---view of washer motor. 3 wires
Pic 4---Middle wire has constant power w/ the key ON.
Ground your test light and check for power.
Pic 5---Left side wire is the ground signal from the switch to the front washer.
I jumped the test light from the middle wire(power) to the left wire(ground) and turned the washer switch ON.
The test light should light up completing the circuit.
If all these checks good. Then you can assume the washer motor is bad.
Attached Thumbnails Front and Back windshield washer dead?-img_4264-copy.jpg   Front and Back windshield washer dead?-img_4267-copy.jpg   Front and Back windshield washer dead?-img_4258-copy.jpg   Front and Back windshield washer dead?-img_4261-copy.jpg   Front and Back windshield washer dead?-img_4263-copy.jpg
Old Mar 24, 2010 | 11:05 PM
chachacha's Avatar
chachacha
Nad1370, you're the man. many thanks
Old Apr 27, 2010 | 11:15 AM
Zieke's Avatar
Zieke
I have the same numbers on my pump, but could not get them to come up on amazon to order a replacement. Where is the best place to order it and the correct number to order? Does the motor just pull out?
Old Apr 27, 2010 | 12:06 PM
lexus114's Avatar
lexus114
I got mine from the Lexus dealer,it was around 60 bucks. It just pulls out of the tank. I tried the Toyota dealer first,but they didnt have it in stock. It was like 20 bucks cheaper too.
Old Apr 27, 2010 | 08:42 PM
carguy07's Avatar
carguy07
Toyota Part # 8533020470
http://www.trademotion.com/partlocat...&siteid=214915
$40
Israelq95
Apr 17, 2019 04:29 PM
emilykatea
Jul 20, 2016 07:36 AM
Boblex
22
Feb 24, 2016 03:21 PM
300s4life
Jan 22, 2010 10:58 AM
