- Replaced Differential Fluids
- parking brake pad replace?
- RX 330 2004 - Trunk Door Lift Replacement
- AFS Front Sensor Location - RX330
- noise when turning right
- Advice needed
- antenna replacement RX 350 FM,AM,GPS
- Buying a used RX350 - Advice Needed
- Cooper Discoverer M+S winter tires are bad for your mpg
- What are the best non-hid replacement halogen headlight bulbs for our vehicles?
- Changing battery question
- Lexus RX 350 AWD Consider Selling
- need instructions on bull bar installation
- Hit and Run - Need to make some Lemonade out of this Lemon life has thrown at me
- New Head Unit question
- Service History?
- 2011 wheels on 2008. Watch out!!!
- Duracell Car Batteries?
- Kinda stupid question
- Does the 2008 RX 350 have an aux input for audio??
- ?? Eibach Springs ... who's got em??
- Trans Fluid? Toyota Brand Best??
- Bridgestone Alenza tires at 45K miles
- how to clean auto dimming mirror gel
- Buy or lease
- Buying a CPO sight unseen - Tips ?
- CD changer - Error 4
- New Toyota Recall
- Voice Recognition Voice Tags
- Valve Gasket Cover DIY RX330
- First thing one does...
- Pros/Cons to a battery unplug to clear codes...
- Annoying Rattles :(
- anyone know what the torque specs are for our rims?
- Airbag codes
- RX350 Tailgate groan
- I got a message from infinirx! He's in Japan!
- AFS sensor - 2005 RX330
- 2009 RX350 Headlights - which ones do I have????
- Poorly sealed headlamp cause HID, Adaptive Headlight Failure
- Steering Wheel squeak when retract???? (RX 330 model)
- anyone use Mobil Super 5W-30 Conventional Motor Oil?
- Installed new tires on 09 RX350 @Costco, Tire light came on, now alarm doesn't beep
- windshield crack
- wheel lock broke
- RX330 Passenger side Head Light CONDENSATION (replacement question)
- Fog light condensation-CPO car
- TMPS lifespan
- Lexus RX 330 2004
- Who lives where it snows and doesn't have winter tires?
- Costco says TPMS replacement common with new tires?
- Overheating after coolant leak fix
- Odometer problem
- Leaking area around trunk, anyone seen this before.
- Overhead Console Box
- Turn signal flasher - how to replace? (for LED conversion)
- Is this a great deal on Michelins?
- "Pay it Forward" Spirit Community Thread
- Valve Cover Gasket Replacement
- Mobil-1 5W30 High Mileage
- Do you include new TPMS seal kit when replacing tires?
- '05 RX330 blows hot air inconsistently
- thoughts on mudguards??
- Need suggestion on expiring extended warranty
- remote start possible with master key?
- 2007 Lexus RX350 Brake warning
- Audio Interface Adapter
- Cd changer/player not working.
- power window switches do not work properly
- Telescope Steering Wheel Noise
- Looking to buy 04-05 RX. Need advice
- Da dum...da dum...da dum...Shark Fin!!
- Headrest DVD Write Anyone?
- Best replacement wiper blades?
- Navigation Question
- aftermarket reverse camera...
- How long can the battery last if head light is on?
- Heated Seat Switch Backlight
- Nav update (04 rx 330)
- Advice About Tires
- reliable, honest lexus dealership in socal
- Issue with Ipod Cable..any clues.
- Service History Questions. Any help would be nice.
- Thundercloud grille
- ML and dvd rear entertainment
- '04 RX330 A/C Light Flashing, A/C not cooling
- 2008 RX 350 - Mark Levison - What are the preferred audio settings?
- Looking to buy (advice)
- Lexus rx400h mileage
- Please help me decide if I'm making the right trade?
- Bridgestone Tire Question
- 2009 RX 350 with a whine
- RX Mark Levinson ML Speaker Replacement
- Lexus RX330 Foot Brake Adjustment
- Apologies for dumb question
- Aftermarket Warranty question.
- Unbelievable problem rx 350 2009
- Question on selling my 2005 RX330
- A question about brake pad service
- Nav/Back up/Front Camera/Bluetooth integration
- I, for one, welcome our new overlords...
- Radiator Hose Change Out?
- Electrical Malfunctions with New Battery
- 2009 RX350 - Question on Door Sills
- Cupped tires
- Squeak at low speeds
- Vote for my RX :) Photo Calander!
- 2004 rx 330 - P0430 code
- RX-330 Yaw Sensor Location
- what are the paint codes?
- 2007 Rx350 battery dying
- navigation update
- Hello, New Owner Advice
- Steering wheel vibrations
- 2011 Navigation DVD Lower Price $169
- Picture Request - Window Lip
- what color wood comes in side the 2004-2006?
- Anyone have their RX400h / 300 brake callipers painted?
- advice on a Lexus RX330, gracias
- 2004 rx330 upper idler pulley noise
- transmission stopped working
- How to transfer Droid2 Global phonebook to 2007 RX350
- CD charger not loading CDs
- RX350 OWNERS, can you tell me what this has?
- 2004 RX330 Air Suspension issue
- 2008 RX350 price ... reasonable?
- Your input matters,,BRAKES
- Extended Warranty: Lexus Platinum or Penske Platinum?
- Led drl
- Tapping into Brake light?
- Buying a used 2007 RX400H...
- 2004 RX330 Liftgate weatherstripping
- 2006 rx rear view mirror ?
- 2005 rx330 question
- What are the steps for removing the rear bumper cover on a 2009 RX350?
- Where to run power cable through firewall?
- ignition coils
- Best car brands from Kelly Blue book...
- Electrical or ignition?
- How much did you pay for your Used RX350?
- How much did you pay for 30k service?
- RX300 Rims on RX350
- what does 4,D,3,2, and L means on rx330?
- Hello, Allow my self to introduce my self
- Question re: suspension in RX 350
- 2007 RX400h traction battery level very low
- Kumho Solus KL21
- AM Radio Recption - Aftermarket HU
- Rattle (in door?) at speeds over 60mph
- Voltmeter install on a 2007 RX 350
- Bosch Evolution Wipers
- First start of day takes a long time
- smoked out Rear side markers / reflectors
- Brake Problems - ABS?
- 2005 RX AWD - Couple of Issues
- AFS Warning light blinking
- Wood Pieces
- 9005 in fogs rx330
- Switched out LEDs in door sills
- Tired of too easy steering.
- Flapping kind o sound
- DIY white LED interior lid door handles
- Suggestions for Rotors/brake pads
- A/C compresor engaging and disengaging on idle
- 2nd gen RX clone
- Replaced my amber led foot well with bright white leds
- RS330 Key Code Location
- The A/C condenser
- Windshield with rainbow specs?
- Levinson Amp Location RX330
- RX330 AC runs great for 5 minutes then shuts off
- TPMS on new tire
- 2004 Lexus RX with 100K miles, What's it worth?
- my spindle is bent !
- What's lost with OEM Navi/BT/camera system with an aftermarket Navi DD
- Full Flush vs Oil Change - Transmission RX330
- Power liftgate won't close, just clicks
- will 10w30 oil work on an 08 rx
- Clunk noise when reversing: tranny?
- Security Light Blinks Constantly
- '05 RX330 Cold Air Intake - any recommendations?
- Advice help needed to replace 2005 RX330 Engine
- It's coming, your phone will run your car's electronics...
- Solving the mpg mystery on my 2008 RX400h
- 2008 Civic LX 21k miles OR 2006 RX330 100k miles HELP!!
- How to reset windows to default on 2007
- Recalls - Is there a time period?
- 2007 RX 350 AWD. Good deal or not?
- Mann oil filters
- Wiper Blade/Insert Application Guide
- 2004 Lexus RX 330 Tire Change
- Need Advice on Used RX330 Purchase
- steering wheel shakes when high speeds
- Thinking of purchasing 07 RX 350 with 113,000 miles NEED ADVICE!!
- Volant Cold Air Intake installs on the RX
- Please help- check engine light
- Anti Theft Alarm -- Automatic Shutoff?
- Best iPod integration for 05 RX330 w/ Nav?
- The average Lexus race driver...
- APEXI World Sport 2 Exhaust
- 90,000 Mile Service
- Where Does Interior Air LEAVE the Vehicle?
- Air Pressure Monitoring System
- Extended Warranty
- Factory HU & AMP - Added SUB & AMP (Low output to sub..??)
- Daylight headlight HID retrofit question?
- I'm Stil In Awe of Lexus Quality
- VVTI Oil Line Burst- Warranty Refund
- Reverse light wiring location
- Flat after replacing set of tires 1/2 year later
- rx400h water leak?
- High beam Bulbs
- 2007 Leaking Steering Rack
- Melted Plastic in Rear Boot Opener
- Lexus rx330 awd radiator replacement
- My RX330 Slow(hesitate) accelerating ....
- I've decided to go with a mesh grille.
- Need to buy new rx350 recommendations?
- procedure for accessing the glovebox LED
- Is this a right value for Used RX 330?
- Transfer Case and Differential Oil
- 2006 RX330 Whiny Tranny
- please help - how to remove glovebox surround?
- 2007 RX350 Idles Rough
- Best Roof Rack attachments for 13' kayak
- Replacement RX 330 upgraded crossbars needed
- 2009 RX350 aftermarket double din headunit install questions
- Anyone applied 'chrome' trim around their windows?
- Anyone fitted LED DRL (Daytime Running Lights) to their Rx ?
- Bumper oh Bumper
- 08 RX Battery
- 2008 USB connection
- US parts compatible with UK RX400H?
- Led bulbs help
- Is there any way to manually close a moonroof?
- My Moonroof is stuck on my 2005 RX 330
- Sluggish Outside Temperature Gauge
- 05 RX330 Timing Belt Replacement DIY?
- When do I replace Drivebelts - 2005 Rx330
- whining sound on deceleration from ~45 mph. definitive answer?
- RX330 fuel filter change.
- OK Gang, what is your summer MPG? City and Highway
- GPS Upgrade
- RX 350 Drain Line Clog - water on floor
- Lexus RX models - Best All-season tire choices
- Brake Replacement
- Bluetooth: Can you pair more than one phone?
- Illuminated Entry
- Anyone swapped the rear courtesy light for a dual light unit?
- Wheels Spacers/Adapters
