W58 weak points
I'm just trying to get a grasp on common failures among W58 transmissions. I see a lot of posts saying their tranny took a dump on them but they don't say what part of the transmission actually failed. I do see some consitent failure in the 3rd gear syncros, but i just want to be absolutley sure about it. Also if there are any other weak points in the transmission i would like to hear about them. Sometime in the future i plan on either NA-T or swapping in a 1UZ into my car, either way big power is the goal and i want to keep all weak links in check.
3rd gear grenades under high torque stresses. Syncros wear out in 2,3,4. Other than that its not bad but its not built to handle big power so 400+ go another route, less than 400 youll be fine if you drive it correctly.
My younger brother's w58 took a dirt nap after we started running Royal Purple fluids. Never again will I run these fluids. But anyway, 3rd gear was the first gear to go. Then 1st. We ran the car at the track on the daily with a 150 shot of nitrous and some sticky rubber. Im hoping to go turbo sometime in the future. Im also planning on running the W58 until it gets stuck. They I will rebuild.
usually its 3rd gear but when the syncro goes it either breaks or the gear itself can break. those chunks usually cause other gears to go soon after.
if you know how to drive and dont "rip" it into gear you should be fine NA-T or 1jz.
i know people that blow the trans on stock power.
my buddy blew the diff in my SC on stock power. when i went to Sound Performance to find another stock open diff the guys looked at me like i was crazy that i blew it with the car being all stock.
basically your driving style will be one of the biggest factor to your cars reliability. not saying to baby it all the time but to know how the mechanics of the car work and what could break if you do certain things.
Really great advice. I know someone else that blew their diff on stock power from always launching it off of every intersection they come across. I learned to baby mine. Changing these things out is just too much work.
A fluid change is next on the list for my next service checkup, ill probably go with GM synchromesh or Redline, synchomesh most likely though. Sometime down the line ill drop in an LSD before the turbo comes in and reeks hell
My W58 handled the 540whp/500wtq for 6 months of daily driving, without an issue. It actually never let go. I just knew that the getrag was the safest bet, so I went ahead and upgraded. Rolling onto it isn't what's gonna hurt it, launching it is what does that, so as long as you avoid that, and don't slam gears, it should be fine.
yup. i will be getting my car retuned on e85 this monday. we will take it up to around 550-600rwhp on the w58. I hear that as long as you dont drag race(from a stop) or bang the gears you should be ok. We will find out really soon I guess. I plan on doing only highway pulls anyways...
I have heard that if you do a hard highway pull you will also blow it at high speeds. In any case, why is it that so many people think it is okay to go up to high 100+mph on the freeway? Please let me know which highway you are going to do this on so I can be sure to not be on it when you are....
