Sponsored by: CARiD
Need help on HIDExtra kit
Old Sep 24, 2010 | 07:49 PM
LexAnt's Avatar
LexAnt
Default Need help on HIDExtra kit
So I just got my HIDextra kit, and I must say fabulous service btw.
Anyways, I ordered a foglight kit for my Tundra since it already comes pre-wired for fogs, I just didn't purchase the option. Anyways, I install everything, and it all works just fine with the regular halogens for the fogs so I know that install is correct.
Now I go to put in the HID kit along with the wire harness. Everything's all tightened down on the wire harness (ground, power, ballasts, oem connector for signal) but nothing lights up. I test the relay with the relay from my low beam wire harness, same result. I swap the ballasts over to power my low beams, ballasts are fine. I test the bulbs with my low beam ballasts, bulbs light up fine. I'm completely stumped as to where the problem is. I know the wire harness is getting the signal from the OEM connector since if I plug in the halogen bulb, it'll light up.
Any help would be great! TIA.
Old Sep 25, 2010 | 12:21 PM
LexAnt's Avatar
LexAnt
n/m, after leaving the problem for a while and getting a good night's rest. i found the culprit to be a bad crimp on the hid relay harness for the ground connector.
1ballnlex
Mar 8, 2011 08:27 AM
andboom
Lighting
Nov 14, 2010 07:44 PM
prankster
May 20, 2010 05:19 PM
Supremeg56
Lighting
Apr 10, 2010 10:13 PM
UncleRay
Lighting
Jan 10, 2008 08:38 PM
