Sponsored by: CARiD
Ballast inside headlamp, is it ok?
Old Dec 30, 2010 | 10:49 AM
JesLet's Avatar
JesLet
Default Ballast inside headlamp, is it ok?
I have Denso ballasts and I figured I can place each inside the headlight.
Is it ok if I do that?
I know that if one of my ballast failed I have to reopen the headlight again, but I can live with that.
Of course I have to wire everything and test them if they are working properly before resealing. Any disadvantages by doing this?
Thanks.
Old Dec 30, 2010 | 11:23 AM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
oem cars are like this, mostly attached to the headlight housing. but the SC headlight is kinda oblong so i hope its the slim type.
Old Dec 30, 2010 | 11:31 AM
JesLet's Avatar
JesLet
Oh, it is for friend's Civic headlamp.
E46 and C-Class Benz cars has ballasts located under the headlight. I used to have Nissan ballasts and they warm up after a while, this just came up to my head, so probably a bad idea?
Old Dec 30, 2010 | 11:34 AM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
not a bad idea, it hides the ballast from view in the engine bay if u mount it on the headlight. a bunch of oem manufacturers put the ballast under the housings.
Old Dec 30, 2010 | 12:08 PM
JesLet's Avatar
JesLet
I am thinking about placing it under the headlight, sometimes water gets under there, how sensitive are Denso ballasts when it comes in contact with minimal moisture or water? The ballast's terminals ( red/black wires ) are open unlike the BMW's / MB's ( Hella ) terminals are sealed inside the headlight.
Old Dec 30, 2010 | 12:42 PM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
well anything electrical + water is no bueno lol. heat shrink and electrical tape the posi and neg and u should be good.
Old Dec 30, 2010 | 01:06 PM
xuserx04's Avatar
xuserx04
Yeah those ballasts sit in a separate little compartment in my LS430 headlights probably to protect them from heat and moisture.
Old Jan 3, 2011 | 03:27 AM
<VENOM>'s Avatar
<VENOM>
My factory ballast are attached to the underside of my headlights, noticed that when I was installing my HID fogs, the ballast should be rubber injected to insure that the are waterproof/shockproof, the wires/connections should be sealed just as well
Old Jan 5, 2011 | 06:00 PM
dkhuynh's Avatar
dkhuynh
you mean like inside inside the headlight?
Zmon
Aug 11, 2021 03:34 PM
littleyan9
Jan 8, 2020 03:54 PM
2genIS
Sep 7, 2017 09:32 AM
BrightonB
Jan 6, 2013 07:47 AM
VAttorney
Apr 13, 2011 07:08 AM
