Sponsored by: CARiD
HID conversion bulb goes out sometimes
Old Feb 6, 2011 | 06:12 PM
Omega99's Avatar
Omega99
Exclamation HID conversion bulb goes out sometimes
First off, I've had a mobilehid.com kit installed on my 2006 IS350 for about 2 years. A few weeks ago I noticed my driver side headlight started to get condensation on the inside of the lens when the car was driven in the rain. I figured I would check around all the places moisture could be getting in to the housing from the back side when I got a few hours to spare. Not a pressing issue since the car is parked out of the rain under a carport.
Well, the last couple of nights when I pulled back in after being out for the evening, I noticed my driver side light was out again.
Tonight I made a point to watch and see if I could catch it. After it goes out, I shut the lights off then back on, and it fires back up. It seems the light goes out with no particular pattern. Going down the road or sitting at a traffic light. In 3 mins or in 10 mins. Doesn't matter. During a 30 minute drive it went out 6 times.
I need some help guys. I'm sure I can find where the moisture is coming from, but the intermittent bulb problem has me stumped. Bad bulb, bad ballast? Any ideas?
Old Feb 10, 2011 | 01:42 PM
tardorange's Avatar
tardorange
Bad bulb my OEM ES350 HID bulb was doing that. I had to get it replaced.
Old Feb 11, 2011 | 05:34 PM
ModExpress's Avatar
ModExpress
Former Sponsor
A simple isolation test would find your problem.
Swap the ballasts on each side, if the problem persists on the same side you have a bad bulb, if the problem switches over you have a bad ballast.
Find out if the bulbs are powered by an AC or DC ballast and then find the correct bulb or ballast replacement for it.
Hope that helps
MiamiIS350
Oct 16, 2014 08:18 AM
Chekmi21
Aug 29, 2013 04:46 PM
horent135
Feb 20, 2012 06:06 AM
rizzy
Aug 16, 2010 01:27 PM
inrainbows
Feb 2, 2008 12:48 PM
