Sponsored by: CARiD
HID kit with-out any drilling ??
Old Nov 24, 2010 | 02:19 PM
rockinalex's Avatar
rockinalex
Default HID kit with-out any drilling ??
is there an HID kit that does not require drilling on the dust compartment housing and that is more of a plug and play installation ....
Old Nov 24, 2010 | 03:21 PM
dealer374's Avatar
dealer374
Yeah pretty much all of them are PnP. Only drilling would be if you wanted to mount the ballast a special way. Dont know where you heard that.
Old Nov 24, 2010 | 04:10 PM
Booyah's Avatar
Booyah
For low beam HID--no drilling just plug and play!
Fog lights--minimal drilling into plastic so wires can come out back, easy!!!
Old Nov 25, 2010 | 01:19 PM
rockinalex's Avatar
rockinalex
OH alright i heard u had to do some drilling from several friends thats why.. but good to make sure i dont...im going for a stock look, how bright should i go ?
Old Nov 25, 2010 | 08:34 PM
Booyah's Avatar
Booyah
4300K to 5000K is the brightest out there!
Old Nov 26, 2010 | 03:15 AM
Jetfire's Avatar
Jetfire
Royale with cheese
if you don't use a relay. you can stuff the ballast inside the housing.
Old Nov 26, 2010 | 08:52 AM
chikoo's Avatar
chikoo
For the IS, you need to drill. Unless you get a real slim ballast.
Old Dec 10, 2010 | 08:12 PM
Kira X's Avatar
Kira X
桜犯罪シンジケート
CL Folding 10,000
I heard you were supposed to drill a little hole when you install HID's? I didn't since I don't have a drill though.
Old Dec 11, 2010 | 09:12 PM
rockinalex's Avatar
rockinalex
yeah i think im gonna go with 4300k... what is the purpose of a relay ? im really bad with stuff like this.lol
Old Dec 12, 2010 | 04:15 PM
Jetfire's Avatar
Jetfire
Royale with cheese
the power from a relay comes directly from the battery, so the power is constant. the power from the bulb connector is not always constant. so you get some flickering.
with a relay, you also have a fuse to protect the HID kit. it's cheap to replace the fuse, expensive to replace the whole kit.
make sense?
Old Dec 14, 2010 | 01:31 PM
rockinalex's Avatar
rockinalex
yeah it makes sense... thanks. so the smart thing to do is get a relay with the kit ?
Old Dec 14, 2010 | 03:34 PM
ModExpress's Avatar
ModExpress
Former Sponsor
Drilling is optional if you want to run the wires to the outside of the dust cap and down to where your ballast is, assuming you want to mount the ballast on the outside of the headlamp.
Relay harness is always optional but recommended, HID kits upon start up draw a surge of power to ignite the ballasts, this prevents your stock harness from frying and gives you a constant power draw to your kit. However, an HID kit frying a stock harness is very rare.
Old Dec 14, 2010 | 04:33 PM
vwynn's Avatar
vwynn
why drill... 3m double sided TAPE!
Old Dec 14, 2010 | 05:40 PM
rockinalex's Avatar
rockinalex
cool ! well any recommendations where to buy this 4300K HiD kit ?
Old Dec 14, 2010 | 07:37 PM
ModExpress's Avatar
ModExpress
Former Sponsor
Follow my signature, just finished making it
ThermonMer
Dec 7, 2011 05:58 PM
mcqmcg
18
May 18, 2011 09:26 AM
hoonami
36
Apr 1, 2010 08:28 PM
huerdo623
Lighting
18
Oct 8, 2007 12:37 PM
NAZTY97
Oct 7, 2002 03:39 PM
