- Upgrading the shifter to 97 + model
- headlight question?
- Can I Change turn signal lights into fog lights?
- Lexus Information Collective (See inside -- 5.0L Stroker Kit for SC4)
- Nak or Pioneer?
- What exhaust did I see?
- Here is my PROTOTYPE of a SC4 intake
- Ikon...still got carfax?
- Almost at the century mark
- Timing belt change 60K or 90K??????
- putting 97+ body panels on 92 sc400
- No Scheduled Maintenance
- Metal rattling sound from under the car
- Lexus Chicago meet.
- ******paging... "RHart00" on Intake INFO from Import Tuner...
- Auto math calculators....pretty useful!
- Btought to you by the Letter "L"
- SECOND part request PLZZ HELP!!
- do they make the corner Bulb in different colors then Amber and clear?
- Brakes
- New to the forum!
- Buildup Recommendation 4 A Newbie:
- wut kind of kit is this?
- how's the ride
- do it yourself clear corners
- Resetting ECU-Which fuse exactly?
- Paging 928owner
- Rebuilding engine?
- SC Rear Wiper??? Where do I get one??
- List your 1/4 mile Times!
- Exhaust by Borla
- Emblem problem (Help SC300TURBO)
- New clutch pics!
- Pics of the car I'm going to buy
- They took my paintjob and put it on an Integra?!?!?!?!
- Garette GT BB Turbo kits
- Instrument panel lights (?)
- Chicago area meet
- Anyone believe this? 13 HP with spark plugs?
- Do japanese sc400 come out with factory LSD ?
- After Market Stereo for SC400?
- Ikon, Carfax please
- can i find a cap and rotor from Kragen autozone etc..
- Weight distribution in SC300 ?
- Formular=Detonation +Knock Sensor=PCV ..?
- TV's in the SC
- Car from Spain
- Indiglo Guages?
- Front right speaker and factory phone just went dead
- alternator replacement
- Any info on converting auto to manual on a sc400 V8
- Trac and Brake Lights
- How has the camry with a sc
- Still need Pioneer OEM radio
- Odometer Needle light not working
- S-AFC questions
- Anyone with a bad Nakamichi?
- Will these wheels fit on my SC?
- Hot Air!
- A little off subject...Shakira... :)
- HID headlight setup...use stock "levelers"?
- 92 Lexus Sc 4oo door panels ( where to find them)
- sc-400 vs gs-400?
- S-AFC questions?
- club lexus
- 1995 LEXUS SC 300 for $6,200
- Power steering pump SUGGESTIONS!!!!
- Florida Fine Cars in Ft. Lauderdale/Miami Area
- shift knob replacement for manual '92 sc300
- Ok, I just got a radiator & thermostat
- Girlfriend gets new Rack.....
- sc speakers
- SOARER emblems on SC400
- Aftermarket Intake For SC300
- Aftermarket stereo?
- sc300-gs300 differences
- sc300 and supra suspension/exhaust parts interchangable?
- SC max horsepower...
- Fuel injector question (SC300TURBO should know) :)
- New moderator...moving threads...please read!
- need a rt side cornering lamp
- I need help changing my radiator
- SC400 radio change sub and amp ??
- A/C unit LCD background light bulbs..
- Auro Spec Headlights?
- To Anyone With A Body Kit...
- Import Toys telephone number
- Cost to have keys cut??
- Tranny fluid??
- winter tires
- SFL SC Meet
- Rear ring and pinion noise
- Nakamichi worth it?
- Someone In Here Must Know How To Remove The Stereo, Pls Post.
- SC 300 upon starting - needles jumping? engine loud?
- SC300TURBO's dyno sheet
- Cd stuck in changer please help!!!!
- SC400 Radio stop working
- Radio antenna replacement
- ATTN: SC300 Car audio gurus
- SC300 car weight...
- Any help please...
- MAX POWER OFR SC 400? +voyager vs gs4
- Dynoed today....
- Burnt out needle/dash repair...
- special gold edition
- keyless entry wont give audible signal
- Power Steering Guru's Heres One For You???????
- Vehicle starting problems please help?
- Dynomatting SC300
- Supra Turbo Engine Install in SC300
- warning light
- What size bulb?
- Black/tan '95 SC 300 For Sale
- driveshaft help...
- Does anyone know how to remove the Nak audio out of the console? thx
- new owner questions
- Dimensions of stock head unit?
- Find something that gets rid of the revlimiter
- SC400 Transmission Fluid
- Battery powered SC300.
- Life expectency of SC400
- Sunroof making noise
- need help - coolant system
- My car was stolen...
- qustion about the back seat
- Request for Wheels
- Airbag warning light
- Is the only difference between the SC300 and the SC400 the engine?
- Center console removal?
- Anyone know of a good SC400 for sale?
- Nakamichi or Pioneer unit switch??????
- Finally found a 5-speed, Opinions...
- Smooth8 How do you?
- whirring/tapping noise when braking?
- CF Driveshaft
- small orange lights on side of bumper.
- OBD-I vs. OBD-II
- List your mods...
- Need SC400 radio, yes checked out E-Bay!
- Who's Blown Car in the Gallery
- Magnaflow vrs dynomax ?
- How do you replace front parking lights?
- Where can I find a 1997 SC300 Nose Mask?
- Has anyone sucessfully polished alloy wheels to give them a mirror-like finish ?
- pics of my sc w/ wheels
- Warning Light problems
- Thermostate location???
- Thinking about purchasing SC400... can somebody fill me in?
- Poor reception , stock radio 1993, some AM stations ?????
- Dyno day results from south FL Supra Lexus meet
- i need help
- SC 400 A/C Charcoal Filter Question
- Newbie questions - FAQ? Stereo? Rims? Performance? (contemplating the SC300)
- Videos: 150 shot WS6 and 2002 Z06 vs SC300 turbo
- Cupholder?
- Performance daul exhaust for sc400
- Time to lower..
- SUPRA/LEXUS South FL MEET..FRI..SAT...SUN
- Chrome Alloy Wheel
- 12 disc cd changer died on my '96 SC300- Please Help, Thank You!
- looking for an sc300
- SC3 and GS3 engines and trannys on E-bay..
- Lexus manufacure warranty and first modifications
- S-AFC and Custom Intake
- check this one...found on GS board.
- DVD/XBOX/COMPUTER setup
- Nak system die. Help, read "can't open door" post below
- which O2 sensor is Bank1, Sensor1??
- Uh........Super Charged SC400????
- Interference or No Interference
- My Nak shut itself off when i go over a bump or make a turn.
- Audio problem...
- yellow fog lights
- cmputerwiz (or anyone else with apexi s-afc)
- Factory Stereo Systems
- alternator or...?
- fuel light = ?? gallons (SC300)
- o2 sensor & exhaust manifold help
- Info on Run-Flat tires
- Desperate search for Black Chrome Emblems
- sc400.com
- No one posts pics anymore
- What's your insurance premium?
- Whose car is this?
- Team Lexstacy Meet, Friday 10/26 6 pm
- [TRACK EVENT] Open Track Challenge
- i think i found the bodykit i want
- Help! can't open the door on the passenger's
- Still looking for MPEG of TT SC 300..I know there's more out there
- MAF Adaptor
- 92 sc300 5 speed for sale
- Post photos of modified SC's please
- 94-95 SC400 stock 1/4 mile times???
- Anyone know how to fix sunroof noise?
- selling parts book for sc3-sc4's
- wheres that idiot clk with the gs3?
- Performance/parts companies?
- Is SC300 5spd shifter HARD TO SHIFT?!?
- fuel smell from A/C
- To all that live in Atlanta. Ga.
- Mileage Consensus
- Torance Lexus meet 818 213 323
- Toyomoto SC300 Kit
- NOS on my SC300: I need info on Fuel Pump and ignition timing
- Weapon R vs. Swiftracing Intake kit
- i know there are a lot of comp. scientist and comp. engi..infact there's a CmputerWiz
- exterior stylin
- Hey you Colorado Guys
- Anyone know what this kit is? *pic*
- Supercharger for SC300
- rear speaker access, how?
- general pricing on 97 SC300
- Water Over Rear Wheelwells
- Eibach Springs
- Questions about the F-Max kit
- lexus emblem
- Older SC with a TON of miles...What should I do?
- CmputerWiz, do you have pics of your MB Quart ?
- Hoe easy/difficult is it to steal an SC400
- Anywhere to get a spare Key besides the dealer
- Help me decide ES300 or SC 300
- 98+ engine swap into earlier chassis?
- squeaky brakes
- taillights
- Valve adjustment for SC300?
- Trunk mounted CD changer question
- 92 SC 400 for sale
- Bad news for the turbo fund
- lexlyf, do you have Dyn's setup?
- Steering Wheel Hub
- Pulled over for 90MPH!
- Brake Pads
- Unable to understand diagnostic code for '92 SC300
- My impression of KYB struts
- Taking off the shift lever... help. 93' SC400
- Fuel Filter Question
- Paging The Ikon, check tittle for me
- Best Year?
- Good place to sell used rims?
- Veilside Body Kit
- rims/speedometer question
- Major Maple Slapdown
- new nakamichi headunit
- Melbourne SC meet.
- Replacing Power Steering Pump seals & O rings
- 120k tune up
- Overheating SC, Please Help!
- Steering rack bushes needed, DESPERATELY!!!
