- Cooling fan on the SC400
- timing adjust??? HELP!!!
- Private Swap
- Is there a better h2O pump then stock?
- 1.5JZ and Engine management.
- loose auto shifter
- Side markers into turn signals
- NA-T or 1jz?
- looking for a good mechanic in san diego
- So, I go to change the fuel filter and look what I find...(56k die)
- Differential Q
- Advice for gated shifter
- Callin people with 1jz swap in Los Angeles area
- distributor smoke
- Will GS400 Axleback exhausts fit SC400 applications?
- Coolant Temp Sensor Location - '95 SC300
- A quick Water Pump replacement question
- hey whats up all..please read.
- clutch master cylinder and clutch pedal won't match
- HEEEELLLP!!!! Car got stuck at work
- swapping ecu, question.
- Belt squeal! Need expert advice.
- IDLE surging and loosing Electric?
- Need your help (Single Turbo Upgrade)
- 1Jz Single Turbo
- Video of a possible tranny issue.
- Sc400 59K engine whine?
- Vaccum hose diagram(?)
- Help installing gated shifter
- SAFC NEO Harness?
- Steering
- Brian Crower 2jzge cams
- Anybody with a 4" dual exhaust setup???
- 1997 sc300
- Bad Jdm Importer In El Monte
- heat comming from floor next to gas pedal
- 1jz soarer swap auto to 5spd!?!?!?! help
- emissions time!!!
- Please help me out
- Aristo cam swap
- 2jzgte and 2jzge pulleys
- Sooo how exactly are camshafts supposed to look like?
- 1JZ auto start problem
- stupid v8 starter... need intake gasket info?
- Manual Transmission
- EGR Delete ?? For non turbo 2J
- to everyone that has a high hp sc ( look )
- Need Soarer Schematics?
- TPS HELP please !!
- Need advice on Plugs/Wires for NA-T
- stock 1jz-gte owners needed!!!
- how much would/did you spend on boost?
- sc400 i need some help
- What is this part? (pic)
- c's short shifter
- 1jz with 2jzge 5spd tranny?
- just a slight teaser
- 1jzgte wiring?
- 1jz swap no start spark/fuel
- Need opinion on P&P job Im doing
- What HP/TQ are you running on your soarer Auto?
- Single exit SC400 exhaust sound clip
- Sc400 Engine Cranks But Doesn't Fire When Warm.
- Missing ECU pin?
- Need Help Car Wont Start (calling All 1jz Owners)
- 2jz into sc300
- SC400 not passing emissions
- Diff Gearing Question..
- Newbee with a big transmission problem
- 92 SC400 switching between Drive and O/D?
- Going to mod my SC400 auto box A340e
- Is this a early soarer tranny or later version ? pics inside...
- What is WOT?
- Power steering pump BEARING
- alternator problems
- Questions not covered yet on 1jz manual to manual (w58) swap
- how to install oil catch can??
- PS pump rebuild tutorial
- Aristo Swap Wireing Archive
- engine bay update!
- Building an exhaust for SC V8: Things to avoid?
- battery help
- ti muffler
- autometer elec. oil pressure gauge?
- SC300 and 1JZ catalytic convertor the same?
- 1jz old pan
- sc 400 swap with 1jz
- Bfi?
- to the 97' 2jz-ge owners.
- Engine whining? Vid..
- turbo debate
- Greddy vs Spearco Intercoolers
- turbo timer HARNESS ?
- SC400 custom 2.5 inch exhaust with Magnaflow
- my pilot bearing wont come out, help!!!
- 02 Sensor Wire Extension harness
- 97 SC400 No Start Need Ideas!
- sc4 power steering pump?
- Will a clutch kit from a chaser work w/ a 2jz with a R154?
- torsen or kaaz 2way lsd?
- Help! My SC Began to Overheat...
- Where do you guys ge the soarer front clips?
- A/C diagnostic code 43 fix?
- Hesitation when I step on the gas throttle?
- am i able to swap rear of transmissions?
- C's short shifter help
- ac lines
- To pull a/c or not to, that is the question!
- 1JZ Swap Help
- Question about V8
- 1JZ maintenance
- E-Shifter From IS300 On A SC300
- R154 swap with undesirable outcome, help please...
- Whats the Best SC400 exhaust system?
- Water Pump Leaks help help.......
- How Do You Add Coolant To A 94 Sc400
- Who does good aftermarket R154 mounts?
- Where to get a reasonable flywheel and adaptor plate for my 1UZ-R154 conv
- Best exhaust to get v8 to rumble? SC400 (RMM/magnaflow)
- quick newbie help
- Question about selling Dave Henry turbo kit
- Potentially scary event, fluid line disconnected
- Starter Help.
- Turbonetics Turbo Kit (93-97 SC300/GS300)
- Code 25 resolution
- New plugs and wires... best choice iv made in a long time
- ITB's for a jz series engine?
- 1UZ question!
- Speedo gremlin.....PLEASE HELP!!!
- New exhaust available: Fujitsubo Legalis R
- Steering Wheel Tilt Down Messed Up...
- So... Which mod closed my R154 Swap thread...???
- Dash wiring
- Help w/ my exhaust system
- What's the Problem?
- Gated Shifter woes
- GTE or GTE style
- Car Dies when i push the brake pedal???
- My JDM 2JZ-GTE Supra Engine Conversion
- W58 help
- Cel code 26, rich air/fuel
- Speedo Problem after 2jzgte swap?
- bad sound in my sc300
- major problem removing y intake sc300
- New Starter????
- New Starter???
- Starts in 2nd gear half the time
- SAFC Neo and first gen 1UZ-FE?
- w58 issue?
- Maintenace or hanging myself hmmmmm?
- How it happen????
- Help-2jz-gte in sc300 swap
- IAT Testing for 1995 SC300
- click, click, starter fix 3hrs, $27 not $271
- Intake for a '98?
- 1jz serpentine belt, no AC but PS, size
- Highway vibration...rear end?
- My Buddy SC400 with Customs exhaust...
- Flex Pipe Help
- Too much for the stock transmission and HG?
- sc300 2jz gte swap
- Fuel pump installation problem pls help!!
- Need urgent help
- ground wire install HELP!!
- AC Scratching Noise
- NEED-2jz gte swap info
- Few preformance product questions
- sc300 spark plug gap question
- Tein test fitting Fujitsubo Exhaust, free? discounted? so cal
- help with bypassing a/c compressor
- Car Died coming to Stop !!!
- My 1jz, How to tell if its a soarer TT auto?
- ***98 Sc Engines Are The Same As***
- ECU questions/help/advice
- harmonic balancer Replacement?
- misfire sc400 (long story)
- Is anyone running a 16lb radiator cap?
- R154 swap, but there's play in the master cylinder
- Car Vibrating on Start up
- Questions and Concerns about na-t
- Fuel pump trouble/DIY replacement
- Fuel Filter Maybe???
- sc300 wont start :( , used to start before I garaged it
- 92 SC400 real-time MPG comp?
- Long story but car wont start, any help appreciated.
- Gave up on the sc400 and picked up an sc300
- which engine swap
- 1jz swap wire question
- Urgent: I'm having a hell of a time dropping my auto, tips anybody?
- Greddy 4 Row Interccooler
- 1jz BOV part # for Blitz or HKS
- w58 tranny question
- Na-t sc...........
- First MoDS in LSD TC
- injen intake on a 98 sc3?
- Battery Light...
- GTE cost.
- 1994 SC400 Radiator replacement
- biggest intercooler with stock bumper
- how to get the specs for a turbo?
- how to remove the linkage from the r154 tranny
- Best cold air intake filter?
- FP ECU Bypass problems
- built tranny any advice or who is good??
- 2jzgte with R154 auto to manual swap question
- ignition breakup or spark blowout ????????
- 1jz oil on plug
- do these injectors fit?
- SC400 motor swap question
- want to go as high as possible on stock twins..
- tac off light is on with check eng, light?
- Sc400 Shutoff When Turn Off A/c
- A/C halp! Interesting...
- Rebuilding 2jz-ge "feel free for any input"
- Carputer setup for real time/datalogging
- Seeking Advice on SC400 misfiring problem.. Codes 13, 14, 24, 31.
- Yet, another R154 related questions regarding the driveshaft...
- Speed Sensor Wiring Question...Gurus step in please!!!
- tach signal wire and best tires for sc400
- need to know all of the parts i need to do a 6speed in a sc300
- fuel filters?
- Should I repair or rebuild my tranny before boost
- Manual Transmission Swap
- battery light wont go away
- questions for drifters.
- Is a loud engine normal for an SC300?
- 1jz-gte on a 99 2jz-ge tranny?
- bucking sc300
- Cam Sprocket Problem
- Serpentine Belt...
- rebuilding and engine questions.
- Guide or info on removing SC400 Trans?
- Will this oil pan fit?
- Water Pump and Timing belt
- Anybody done a manual tranny swap on sc400?
- GT40r vs T67 turbo
- SC400 manual tranny?
- Question With A R154 Supra Trans
- IJZGTE question...kinda weird.
- Crankshaft position sensor
- sc400 air intake question
- TRAC issues still, replaced hose and bled
- CE Light Trac off ?
- Hit the dyno for a baseline [pics]
- IAVC Cleaning
- Spark Plug Question
- how to check engine codes?
- Lsd?????????????????????????
- Supra (MK3) and SC300 1JZ use same downpipe?
- SC300 OBX headers question
