- na-t runs like booty
- My Single Turbo Soarer
- SC300 W58 Carrier Bearing
- Fan Bracket wont come off?
- Fan Oil/Fluid?
- Rebuilding a 92 SC 300
- Plugs, Wires, Caps & Rotors
- Battery, or startup issue.
- This is going to be a PIA the remove (fuel Filter)
- SC's down again.....
- Coolant System flush and Brand questions.
- 5spd in 2jzgte
- need help!!
- sc 300 help
- Interesting Walbro noise issue
- swapping companion flange for the getrag v160 and gs400 diff
- R154 for $700?
- Flexplate Lockup
- na-t to jdm aristo gte with AEM
- anyone have the lextreme cams or torque converter in the sc400?
- Aristo GTE rich idle issue (single turbo)
- 92 Sc400 Crankshaft Issue
- Random low idle
- Pulsar Plugs in a Sc300?
- New to the Lexus scene, looking for people in the DFW, Texas area
- 2jzge intake manifolds
- Need new 1uzfe where to get near Georgia??
- No voltage from pins IGT 1-6 at ecu
- TT head swap ?
- gte vs. ge head
- SC400 driver's rear clunk
- sc300 idles and runs horrible
- is there a t3 2jzge manifold??
- JDM 2jzgte: Restrictor ring and fuel cut?
- 1993 sc300 won't charge
- power steering
- Bi-level / Floor blower question
- Anyone running the GE canister with a GTE swap?
- 2JZ clutch question
- Tampa FL - Need Reputable INEXPENSIVE Torque Converter Swap 93' SC400
- MK3 Supra Clutch w58
- SC300 No Spark
- HKS, Magnaflow, or Megans exhaust - which gives best bang.
- High Rev Shift Delay
- Flywheel & clutch setup for R154/2JZGE
- 1997 SC400 transmission
- No CEL when starting car
- Pre-Swap Help
- jz swap cruise control
- Master Window Switch Cleaning Write-up
- 1.5j questions
- transmission fluid
- 2jzgte r154 after swap issues help
- What is this?
- valve cover gaskets
- help with auto tt wiring
- Can 2jz twins replace 1jz twins?
- 1JZ-GTE with R154 to 2JZ-GTE and V160, who has done it?
- Will a 2jzge A/C Compressor work with a 1jzgte engine?
- Need help identifying a part...
- Sourcing a proper gasket kit 2JZGE
- na-t at25 psi vs. gte at 25 psi
- SMOG TECHS, chime in!
- Tach adapter or resistor mod for a 2jzgte?
- Burning tons of Power steering fluid and soft steering
- Methanol Injection Users
- changing an automatic transmission
- Dead Tails
- 1UZ-FE blower manifold
- Cheap power gains
- What an unadulterated hassle?
- Need serious help replacing my ECT sensor!! HELP!!
- Airbag Indicator Light Came on.
- Sc300
- Stuck steering column
- Performance Chips??
- Installing a gas gauge in my sc300, need to know what sender wire to connect to.
- Sc300 and changing the valve cover gasket
- First ride w/ a Billet 6765.... : )
- Transmission shifting on its own
- Went to track
- Electric Door Locks...& Locks & Locks
- SC400 avg. transmission lifespan
- So Many Threads, Where to start?
- Extra Horsepower?
- Ignition Locked After Changing Speedo & Odometer
- SC400 Spark Plugs???
- sc has trouble starting after sitting 2-3 days. couple time starts then shuts off...
- Trans error code 67 help SC400 92
- Installing IMF headers SC400
- SC400 '95 Hydraulic Pressure Hose leak - 1UZFE
- A/C Problem??? 95 SC300
- Are SC/LS brake lines interchangeable?
- Eh Power Steering
- Crank pulley SEPERATED whos running the driftmotion Crankpulley?
- Which O2 sensors Fit in OBX headers?
- Has anyone ever done this? 1.5JZ
- HELP: 1JZ swap injector issue (no pulse)
- Significant power loss, again! -- Help
- PCV Valve Hose
- R154 disassembled: Is this normal? (video)
- Unplugged MAF = More torque, gas, fun 92-94
- bayarea nor cal tail lights for sale
- ECT Switch on Console
- Thoughts and plans, here's my car
- Need help sc400 ignition issues......
- [93' SC400] New Used transmission installed - car shakes/vibrates badly now
- Drive Shaft Issues
- Whats the cheapest way to Turbo Charge A GE ????
- stockish dyno numbers
- Is this plug needed?
- FCD & SAFC II Wiring Help
- (1992)SC400 egr delete resistor location
- Just got an SC300..tach/speedo issues
- sc400 powersteering hose question
- W58 clutch woes
- '92 sc300 Overheating, need some advise, please.
- Difference between Soarer W58 and SC300 W58?
- SC300 ground cable replacement(for ghost), how?
- how much hp/tq can s400 transmission handle?
- 3 Coolant Temperature Sensors?
- W58, R154, V160, V161 transmission Swap to (1UZ-FE, 2UZ-FE, 3UZ-FE)
- Normal idle for 5spd sc300s
- OBX ITB's???
- Which tranny mount?
- How to remove/install antenna mast?
- Insight on a problem
- r154 question
- MAF replacement
- Leak here and there...is this supose to be there?
- Out with the Aristo tranny
- 1jz hose question with pics (SC300 swap)
- 2JZ T67 Swap
- Help with exhaust
- 2jzge-t or 1jzgte....
- 1JZ Auto trans not wanting to shift
- Coolant reservoir tube help
- i want to make my sc300 faster???
- Dual fuel pump question ??
- Quick Lean Spot at 3k Rpms (1JZ,440cc,etc)
- Two pink wires from inst. cluster/ which one for speed sensor?
- 92 sc400 trans fluid??
- Supra belt tensioner dampener: Who is running one?
- Tps????
- Double Trouble Reading CEL on 92 SC400
- too much fuel
- Possible to decrease clutch pedal travel?
- 1jz vacuum pressure question....
- Window Problem
- How to remove Pilot Bearing with a Doughnut
- Coolant overflow / reservoir
- Autozone Rack and Pinion
- Hardtop SC3/4
- [1993 SC400] Did my Torque Converter just instantly die?
- 98 SC400 Power steering acting wierd.
- SC300 OE vs Universal Type O2 Sensor
- 1jz sc400 swap problems
- 98 1UZ VVTI into 93 SC400
- Map Ecu 2 Launch Control help
- sc400 EGR DELETE --still throwing CEL code 71
- SC300 Boggin Out!!!!!
- Input on intercooler sizes
- 1jz problems..
- electric fans from supra fan shroud
- High idle on cold starts and low idle once warm?
- TTC help
- Anyone else have their LS400 calipers high polished??
- Timing belt jumped a tooth. Now what?
- Part numbers for Supra heater hoses?
- NEED part number or desciption guys
- '93 SC400 Telescopic Steering Column Question
- where to find? SC400 upgraded ECU or ECU upgrade
- Distributor cap & rotor replacement w/ pictures
- SC300 Window Issues
- Making my own headers
- Ultra Gauge
- Transmission whine
- transmission swap 1jz
- Engine Replacement
- Harmonic Balancer: help ASAP please
- Engine shakes at 2000rpm, about 3000rpm and so on.
- Plug Wire Resistance
- 5 speed swap
- Ignition GURU assistance please...
- nos kit 05000
- New to CL
- soarer 1jz high idle, no boost, temperature soar, and some other questions
- hey yall..
- I don't know what this is...
- 1jz starting and warming problems
- FIXED: No check engine light for 95 sc300's w/1jz swap
- New LSD, how hard to DIY??
- Starts perfect cold, wont start when warm?
- Battery question...
- 1jz no start problems
- new car need a little help
- Suprastick trans computer?
- Crazy 3000rpm Idle
- Cleaning Maf
- 60 MPH @ 4,000 RPM Is That Normal? HELP!!!!!
- Has anyone ever done a 1jz head on stroked 2jz?
- xx400 Headers
- Someone with a Manual, what does..
- 92 Sc400 Code 25 Air Fuel Ratio Lean Malfunction
- Rear main seal leak fixed for $6 vs $2300
- quick battery question
- Solid answer on Q45 TB on GTE ECU...
- 92 SC4 ac compressor leaks common?
- 1jzgte heads on a 2jzge bottom
- 1uz w/ w58 Gas mileage
- what is the max power that can be pushed through my transmission?
- Storing car 6months +??
- Quick question: Which alternator to buy?
- Engine Oil hot light?
- Car died on the road. Starts-then dies immediately
- Power steering frozen at idle, but eases up while revving..?
- 5spd swap, what about clutch switch?
- 94 SC300 MAF sensor cleaning with electronic parts cleaner
- 7mgte 440cc into 2jzge write up?
- Long shot A/C help
- Help, timing belt idler bolt is loose
- oil change+new tank of gas= ROD KNOCK?
- 1993 SC400 clutch
- BHG? time for NA-T, and then BGH!
- 2jzge 143-count timing belt diagram
- outside door handle
- Wiper Inserts
- helping finding a good diagnostic mechanic in MD/VA
- Water build up on passenger side carpet
- New problems I could use help with
- Swap or clean out?
- Bosch F5DPOR Side Fire Plugs on a 2J?
- help me located this hose!
- Bad injectors?
- Can a novice change plugs wires?
- turbo noob..need some info :)
- Any advice? hard start, no acceleration
- auto to manual guys NSS bypass
- Thermostat housing for Aristo swap?
- MAF code --->Oxygen sensors
- IMF headers...
- Confused can't find fuse for the fog lights
- timing belt / water pump change -- special tools needed?
- Transmission Question
- 1j exhaust for the sc
- what am i looking at here?
- Car cuts off when it heats up???????????????????
- Started Smoking then Stopped!!! Ideas?
- ok to use safc 2 with aristo 2jzgte stock boost?
- non intercooled stock comp boostin :)
