1993 sc300 won't charge
Old Oct 4, 2010 | 07:19 PM
idahobob's Avatar
idahobob
Default 1993 sc300 won't charge
Need some help PLEASE. I replaced the clutch in my 1993 sc300 went to test drive it and it wouldn't start. I check the fuses and the ALT fuse was blown and the radio fuse. I replaced both of them and it started but it drains my battery while it is running until the car dies. I pulled a battery cable off and it just dies instantly. So I bought a new alternator put it on and it still drains down the battery when it's running. It also blew the radio fuse again.
Any suggestions? Please, my wife is yells at me every day it is broke down.
Old Oct 4, 2010 | 07:32 PM
masagsxr's Avatar
masagsxr
Thought it was the alternator.. You sure you have it wired correctly? Might have crossed grounding or a short somewhere?
Old Oct 4, 2010 | 07:54 PM
scviolence's Avatar
scviolence
bro u have a short somewhere...and since that radio fuse keeps popping id hop down and check out that fuse box....im not sure if it was the sc's or not but i remember a thread on a car that had a shyt ton of corrosion on the fuse box...idk just giving ideas...hope u get it fixed.
Old Oct 4, 2010 | 08:26 PM
idahobob's Avatar
idahobob
I checked all the connections fuses wires etc. that I could access, nothing appears to be cooked, rusted or wet or loose. Everything was fine till I replaced the clutch. I put the positive on the + and the negative on the -.
Thanks
Old Oct 4, 2010 | 09:40 PM
masagsxr's Avatar
masagsxr
Since you replaced the clutch, that means you would have to bring the tranny down. Did you by accident pull the wires out on the tranny? Sensors? Reverse sensor switch? Check the wires down there.
Old Oct 4, 2010 | 09:50 PM
idahobob's Avatar
idahobob
There's only the 2 sets of wires correct? Will check them again to make sure. Thanks
Old Oct 4, 2010 | 10:01 PM
masagsxr's Avatar
masagsxr
Not sure... I have an auto tranny and its been a while since I owned a manual. It is probably just 2. One ground and the other to a switch to trigger the light (positive). Maybe you've swapped them by accident?
Old Oct 5, 2010 | 08:00 PM
idahobob's Avatar
idahobob
Thanks for the help I figured it out thanks again.
Old Oct 6, 2010 | 08:10 AM
Mike552's Avatar
Mike552
What was the problem?
Old Oct 7, 2010 | 09:55 PM
topdog849's Avatar
topdog849
is your battery light flashing? try getting 1 jumper cable and connect it to the alternator batt terminal and the other side to battery positive. then then check if your battery light goes away
Old Jun 17, 2013 | 11:12 AM
alto832's Avatar
alto832
Nice he fix it and didn't say how
My 1993 sc300 won't charge car was running fine until
I swap batteries with my friend
He's car die so I told him let's swap batteries let my car
Charge it
Worse decision even
Please help now
Old Jun 17, 2013 | 07:27 PM
2jznosht's Avatar
2jznosht
http://www.lextreme.com/alternator.html
best of luck
tzxlyd
Mar 30, 2017 06:14 AM
Kpilgrim
Aug 7, 2011 05:28 AM
mb12345
Mar 9, 2011 07:22 AM
SirSam
Jan 13, 2006 07:45 PM
