Someone with a Manual, what does..
Old Aug 18, 2010 | 06:24 AM
DirtDiggz's Avatar
DirtDiggz
Default Someone with a Manual, what does..
the little yellow oil sign with the ~~~~ under it mean? It comes and goes but I'd like to know whats causing this, thanks!
Old Aug 18, 2010 | 06:26 AM
nfordhk's Avatar
nfordhk
Im not sure what it means but im sure its in your manual have you checked that?
Old Aug 18, 2010 | 06:28 AM
sc4fanatic's Avatar
sc4fanatic
oil level low...
1- low oil
2- oil pump going out (pray not)
3- need oil change
gl...
Old Aug 18, 2010 | 06:34 AM
DirtDiggz's Avatar
DirtDiggz
Check the thread title, I said someone with a manual. lol
Thanks anyway
Old Aug 18, 2010 | 06:35 AM
DirtDiggz's Avatar
DirtDiggz
Originally Posted by sc4fanatic
oil level low...
1- low oil
3- need oil change
gl...
Thanks you, much appreciated
Old Aug 18, 2010 | 08:46 AM
good2go's Avatar
good2go
oil level low...
1- low oil
3- need oil change
gl...
I'm a little confused about your #3 in this list. What makes you think a "low engine oil" level light could mean you need an oil change???
Old Aug 18, 2010 | 08:48 AM
tuterz's Avatar
tuterz
i think its the oil pressure light.. which is not good..
Old Aug 18, 2010 | 08:49 AM
tuterz's Avatar
tuterz
wait you said yellow.. not red... i think you're just low on oil.. top it off with some oil..
Old Aug 18, 2010 | 09:48 AM
Luxor's Avatar
Luxor
Thanks anyway
I have the manual in front of me.
"Low engine oil level warning light"
Old Aug 18, 2010 | 09:54 AM
good2go's Avatar
good2go
Thanks anyway
IDK if this still works, but I suggest you at least give it a try:
https://www.clublexus.com/forums/gre...teresting.html
Old Aug 18, 2010 | 09:58 AM
DirtDiggz's Avatar
DirtDiggz
Thanks, will try!
Old Aug 18, 2010 | 10:19 AM
Luxor's Avatar
Luxor
^ That is how I got my free manual.
Old Aug 18, 2010 | 12:18 PM
nfordhk's Avatar
nfordhk
Thanks anyway
lmao my bad for some reason I thought you were implying manual like the transmission. I was thinking I don't see the difference but ok. haha
Old Aug 18, 2010 | 01:26 PM
DirtDiggz's Avatar
DirtDiggz
lol, its cool, i thought you were being a d!@khead
Old Aug 18, 2010 | 01:54 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
lol, you don't want to confuse oil pressure and oil level lights.
The low engine oil level is in the middle of the RPM TACH and has the squiggles under it.
The low engine oil pressure is in the bottom right corner and has one drop falling out of it.
One is much worse than the other obviously.
check out post number 2
http://www.soarerworld.com/forum/showthread.php?t=27488
