- SC300 power steering not working... even after changing PS pump
- Sc300 wiring help
- '92 SC300 Electronics Woes. At my wits end
- Tail brake light won't go off
- Location of coolant temperature sensor? 1999 SC300
- Safe boost on stock Jdm twins 2jzgte
- STRANGE or normal Throw out bearing noise...
- door lock sensors interchangeable?
- car shuts off in reverse!?!?
- Buzzing from fuel pump and whinning from fuel rail
- I want more power out of v8 sc4!
- If you don't know what the hell you're doing, PLEASE stop offering to "help"
- Has anyone here swapped in a 370z 6-speed transmission?
- Need help with removing ignition lock
- EASY O2 sensor question. PLEASE HELP.
- 1993 SC300 heat coming from center console
- Where does this plug in???
- The dreaded engine surge
- Preventative Maintenance Before Engine Replacement
- Climate control won't get power/signal
- W58 on 1uz questions
- Post a video of your SC300 w/ muffler deletes!
- Sc400 manual swap from hell!
- In need of assistance from the crew...P1755
- ge 11mm vs. gte 14mm fuel rail
- Need Help With Coolant Temp Sensor and Sender Issues
- W58 5 Speed Swap Drive shaft
- 1992 SC300 AC Just Stopped
- Bought wrong alternator!
- emissions fail!!
- Power windows and sunroof no longer work
- Tundra Headers, will they fit???
- High pressure power steering hose 95 SC
- excess pressure in the gas tank
- Hydro-pump specs?
- Changed fuel filter, car won't start
- Poly Exhaust Hangers
- What could it be? Fpr or a fuel pump?
- which torsen lsd is this...Not mkiv auto tt
- High Clamping Clutch Question (w58)
- What is this sound, Transmission issues, Help - SC400
- Beech performance tps adapter
- 1jz w58 clutch/flywheel set up
- Auto trans won't shift to highest gear
- Fuel Pump High Amperage/Current - FP ECU Bypass?
- Throttle pedal does nothing once warmed up.
- 1jz Vac check valve
- Blackops...Transmission search
- BC cams for NA (Non VVTI)?
- SC400 W58 swap: bad bearings, issues
- what could cause this .....
- Paddle shifting an auto
- Source for MAF
- What Bolts should I get for Nur Spec exhaust tips
- A340E box from Supra in facelift Soarer?
- a question regarding throttle cables.
- new (not stock) power steering pressure line install with pictures
- help my sc wont start!
- Used tranny
- Sc400 stalling when put into drive or reverse
- o2 sensor question
- 1992 and 1993 5spd car updates
- 1993 SC400 lock and anti-theft Engine won't Start
- 2JZ Ge (Swapping SC300 Auto to Manual)
- 92 SC400, Sluggish morning starts
- 2jzGE on DET3 piggyback
- Moron recharging battery
- Crank but no start
- A/C Clutch Power Issue
- Na-t ffim
- SC300/2JZ-GE Fan clutch removal and blade torque?
- gauge cluster bulb finicky-ness
- installed a used ECU
- NA-T SC300 out of storage. Drives well, but idles very lean
- Car still not starting...Pictures
- Titan Cams 280 Pros and Cons
- 1jz sc won't keep running? Please help!!
- 92 Sc400 !! Need new transmission
- Timing problem please help
- 1992 SC300 Check Engine Light Throwing Code 55 - Knock Sensors Tutorials? Write Ups?
- Heater Blowing Only Cold
- Evans coolant
- Sc400 Manual Swap Drive shaft sounds, help!!
- DSPORT magazine dynos XERD header on SC300
- Car not firing, what to check next?
- How true is this?
- Sc400 x-pipe w/stock mufflers sound Clip?
- Pro efi color can gauge users
- SC400 W58 swap - SC300 5 speed parts car?
- power window issue
- SC-300 N/A Max HP?
- How to identify an obd1 throttle body vs obd2?
- 5 speed swap SC400 Los Angeles ?
- 98 Lexus SC400 Resonator Delete
- reverse light wiring diagram!
- SC400 MAF Issue and CEL 31
- Please help with rear diff
- 1993 SC 400 sleepy speedometer
- 1JZ/2JZ Stud thread chaser
- 300 No Start Solution
- question on emissions
- Does this need to be grounded? Found it out in the open
- 700 whp 1jz SC300 Piggyback?
- A curious thought
- Can't find engine block drain for coolant(COMPLETE coolant drain)
- air bag light on and remote entry system not working
- Question about cam/ crank sensors and location
- SC400 Manual Swap CELs
- 4 runner dizzy mod problem
- Can someone please tell me which sensor this is?
- Sc300 bucking and losing power
- Idle balance with/without AC
- Speedometer gear for w58
- any tips on checking your iacv?
- Resonator delete
- Notorious 1j running rich and idle issues. plz help!!!!!!!!!!!!!!!!!!!!!
- 5spd turbo rear diff gearing
- Sc400 sluggish idle and drive
- Transmission filter 94 Sc400
- Changing spark plugs 94 Sc400
- Dash dissasembly
- 95 SC400 low rpm/throttle hesitation/stumble?
- Rough Idle...Need Help
- Bent stud on the stock driver side header 1UZ
- Is this okay? (Starter solenoid)
- W58 to R154 Swap Question
- Side effects of regular gas?
- Fuel Tank Pressure Problem
- new 1UZ-W58 adapter option
- 1jz gaskets and parts question
- Manual Shifter Height Dimension
- Megan VS OEM Engine/Trans mounts?
- Door hinge issue / ECM question
- Help electrical ghost
- 1993 sc300 5spd turbo questions
- Some serious engine issues, SC300
- What range fuel pressure gauge should I order?
- Fuel Pump failure mileage
- New Lexus Owner. Please please help.
- Coolant Leak, need help
- harmonic balancer
- Oily Steering Rack boots
- Looking for a drive shaft upgrade
- Timing Belt replacement experience
- Need Help, Transmission issue
- AEM V2 Strange Shutdown/Cut issue
- power steering cooler for Drifting sc300
- Problem with a 92 SC400...
- adjusting alternator?
- Help with a/c unit intermitent blinking lite
- 1997 high pressure hose from power steering pump leak
- Video explanations of how Torsen and Clutch Pack LSDs work
- Stock hardware for Blitz Nur exhaust ?
- 1JZ Fuel Lines for 500WHP+
- What do you regret NOT doing during your first serious standalone tune?
- New timing belt oscillating
- 92 SC400 Timing Belt/Kit $800
- How hard is 2 find 3:76 LSD
- O2
- Non vvti 1jz cam sensor question.
- Piston needs replacing
- Adjusting idle on tps on Sc400
- Overheating Issues
- Help with Sheila
- Cube Speed W58 Short Throw Shifter
- Any '96 SC400/SC300 DIY Owners out there? (Free to a good home)
- code 13
- Anybody know what size socket to use on front wheel bearing nut
- Question about hydraulic TOB clearance on a w58 sc400?
- Stock Pressure Plate Clamping Force Rating
- Harmonic balancer alignment
- sc300 rough idle then shuts off. Runs after ecu reset
- 1jz SC300 Wont Start
- Best, clean +12V switched power source to tap from in the SC300 engine bay?
- 1995 sc400 fuel pump wont turn on
- Which fan blade to use on Soarer (JZZ30)?
- Help with aristo ecu code reading
- HELP Third brake light
- Moog ES3560 outer tie rod
- Getting an SC4.
- Driver side headlight low beam won't work
- speed sensor question
- could use some advice
- electrical?
- W58 noise?
- Cleaning Iron block surface 1JZ-GTE Headgasket
- Help! Sunroof Stuck...
- 93 SC300 won't start
- How can I test run 1UZ-FE on stand?
- G35/350Z 6-speed on an SC300
- Complete lose of power steering investigation
- Na-t set up / need help with speed cut
- Rear end gearing question
- What Headlights should I get?
- Please help trouble shoot.
- MK3 Auto Supra transmission in an SC300
- What components run off EFI Fuse?
- Racelogic Traction Control Discontinued
- help!
- 93 sc400 ignition/fuel issue
- 92 corner lights to 97 fog
- SC400 cranks but won't start- have narrowed the problem, see inside
- driftmotion AEM V2 1JZ-GTE - car won't start
- 95 Lexus SC300 Overdrive Issue
- 92 sc300 shut off at traffic light - 12v mod still relevant?
- Cigarette lighter doesn't work
- can someone please confirm which plugs to extend
- 92 sc400 shift lock
- Did the 1992 sc300 w58 have an aluminum sandwich plate?
- Tensioner and two failed water pumps?
- Hood doesn't latch and lock
- What emissions is not needed?
- battery dying
- R154 question
- Searched, no dice. Where is best place to add an additional coolant sensor
- sc300 93 headlight bulbs
- 96 sc300 5sp cali ecu vs. non-cali?
- Help Engine Light Code: P0300 P0304 P0306 P0307
- Help finding high beam fuse!!!
- Will I lose low end torque/HP?
- R12 and R134 same climate control unit?
- SC400 piggyback options
- CD009 Swap With JZ - Calling All Members Who Have Done It!!
- r155 transmission a new solution to r154
- Too Chicken To Test Fuel Pump Kill Switch
- Keep hydro fan or replace with clutch fan from LS400
- JDM 2JZGTE VVTi wont start
- Spark Plug Troubles
- OBD2 Monitor Question
- Where is the flasher relay
- 1jz Sc300 Cranks but won't start!!!
- License plate light PROBLEM
- 1UZ-FE engine failure
- Any of you electrical gurus, looking for a way to activate blower on high with one
- What shifter is this?
- what are safe coolent temps (while cruising)
- Weird problem with sc300 electrical
- lack of power need some help
- Who has had their AC fixed / Freon leaks. (AC FIX THREAD)
- Another Window Regulator Thread?
- '98 SC400 Power Steering Pressure Hose Parts Help
- Smog check failing at idle, third time, need some advice
- Transmission crossmember for w58 swap on sc400?
- 1uz w58 bellhousing lengths?
- 1jzgte swap from chaser into 93 sc300 any insight
- sc400 mufflers
- Power Steering Died, now ABS light on?
- TPS/ transmission issue
- Doing a w58 swap with a 240sx master cylinder, have some fitting size questions..
- Advice on removing r154 output shaft oil seal
