I want more power out of v8 sc4!
Old 05-27-16, 11:35 AM
Datsjonz
Datsjonz's Avatar
Default I want more power out of v8 sc4!
I have a 94 sc4 any suggestions in how I can get more power out of this v8. I DON'T WANT TO SWAP TO 1 OR 2JZ I want to keep my v8.
Old 05-27-16, 11:43 AM
plex
1UZFE/2JZGTE
plex's Avatar
Define more power, the returns you get for cost of headers, exhaust, intake may not be best bang for buck.
Old 05-27-16, 11:48 AM
Datsjonz
Datsjonz's Avatar
I want it to have more launch power from a dead stop.
Old 05-27-16, 12:06 PM
KahnBB6
KahnBB6's Avatar
Received 1,216 Likes on 854 Posts
For a horsepower increase:
Upgraded fuel system, aftermarket ECU, used Eaton M-112 blower on custom intake manifold and a rebuilt/upgraded transmission with a performance stall convertor.
However, being in CA... you can't do those things :/ All the things needed for a 1UZ to make more power are going to fail your smog tests.
Things that help performance *around* the stock engine:
There is a slight modification that can be done to the transmission to influence the way it shifts (ie: slightly more response). I am not familiar with it personally but I know it exists.
Another thing you could do is swap from your stock 3.92:1 rear differential to an SC300 M/T or GS300 4.08:1 rear differential to make the gearing more aggressive. And use a YellowBox V4 speedo corrector for that. You could also do 4.27:1 but that might throw off your emissions too much.
Finally, a swap to a W58 5-speed manual gearbox from an SC300 or Supra MKIV NA will do a lot over the automatic transmission. However I am uncertain if this can be legal in CA at this point also.
Other than that... yes, an LS1 swap with all the emissions gear is the only other way to really jump in horsepower in CA. That, or a USDM 2JZGTE with all its emission gear.
Old 05-27-16, 01:06 PM
Datsjonz
Datsjonz's Avatar
Thanks for the info. Smog check is not an issue at this point I can always "work around it". Thanks tho very helpfull now I need to start reading on all this.
Old 05-27-16, 01:17 PM
Ali SC3
Ali SC3's Avatar
nos wet shot
Old 05-27-16, 01:23 PM
Datsjonz
Datsjonz's Avatar
ALI sc3 I thought of that! Lol
Old 05-27-16, 03:48 PM
mikef
mikef's Avatar
you can put really small wheels on it, that will help at launch
Old 05-27-16, 04:38 PM
Datsjonz
Datsjonz's Avatar
I also had that in mind but wasn't too sure... LMAO
Old 05-27-16, 05:41 PM
Zerodrag
Zerodrag's Avatar
If smogging isn't an issue, a 5-speed manual swap would probably make the car a lot more fun to drive.
Old 05-27-16, 06:34 PM
Datsjonz
Datsjonz's Avatar
Would it bolt right on? And do need to change my drive shaft? What wiring would have to be used? Sorry for all the questions.
Old 05-27-16, 07:01 PM
Zerodrag
Zerodrag's Avatar
You would need to do a search on this forum or online. You can get some info from this post also...
https://www.clublexus.com/forums/per...ml#post3014794
Old 05-29-16, 08:24 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Or if you're on a budget and want to keep it auto because yay4stock.
http://www.lexusclub.co.uk/lsocautoboxmod.pdf
Helps to quicken the shifting
Old 05-31-16, 11:52 AM
Datsjonz
Datsjonz's Avatar
Thanks that's good info!
Zoolander
Performance
10-29-15 03:59 PM
briggsypoo
02-05-15 08:43 PM
SC4Stella
25
04-25-13 12:50 AM
gs-ireland
Performance
31
09-21-07 05:44 AM
LEXISM
Performance
08-19-03 05:08 PM
Quick Reply: I want more power out of v8 sc4!
