- OEM Speaker Bracket Hacks
- Towing my 3200 lbs boat with my 2009 RX350
- Evaporator Drain line, not draining ( 2006)
- Parts for my 400h
- 2008 RX 400h won’t start unless headlights are off
- Stereo Power button not working! please help
- Newbie with Questions
- 20x8 | +30 offset | 245/50/20 | will they fit?
- Rx330 & Rx350 Headlights compatible?
- ABS/BRAKE/VSC/(!) Message
- Radiator change ( and what are these hoses)?
- What Brand Brake Pads?
- DIY Illuminated Accessory Port (2004-2009)
- Roof Rack front "Drip" Moulding
- Rear OEM brake pads
- 2nd gen Instrument cluster's
- Tire Pressure Blinking
- 2009 Rear wiper doesn’t return fully to rest position
- Passenger Radiator Fan replacement - Hybrid RX400H 2006
- Lubricant Change intervals
- Vibration help, rear end
- Coolant Vaniishing Mystery
- Broken Hose
- Ultra Racing's $400 rear sway bar..
- Water leaking into front floor from sunroof drain
- 2004 Rx330 change fuel injector now long time to start
- So far nothing but a headache
- Torque converter failure ‘08 RX350
- Oil Cooler and VVTi lines
- Any hotspots or must fix items to keep an eye out for?
- cracked dash
- Back door operation for RX400H 2006
- it was only a matter of time
- Cabin Air Filter tabs won't open
- How to replace INNER tail light assembly - 2005 RX 330
- 2004 Lexus RX330 Red Battery Light and Squealing Noise.
- searched but could not find: description of all wheel drive system for 2009
- Upgraded sway bars
- Lubricant / Fluid recommendations
- Seats have weird markings on them
- Wiper Fluid not coming out of the nozzles
- Rear view mirror, stereo issues - fix? Prior to sell?
- Need urgent advice 2009 rx350 51,000 miles oil leak
- New timing belt and water pump installed
- Door trim color touch up paint
- No heat/air/defrost
- Rear Hatch Open Dash Light
- Good video on Changing the Transmission Fluid
- no a/c on drivers side
- fuel door spring
- 2007 rx350 engine mounts PNs
- Please Help Check Engine VSC
- Rear passenger door not opening from the inside
- Bypass lines on rack and pinion
- Clunk on braking and accelerating at low speed + scraping
- 2006 RX350 Wiring Harness
- 2nd gen 2009 RX350: did they come with an engine room cover on the driver's side, or.
- DRL "Partial" Delete
- Program new key transponder for free.
- ABS, VSC, Brake warning light on dash after brake switch replacment. What next?
- 2004 RX330 catalytic code issue
- Water Leak at the Back Door Hatch 2006 RX400H
- Clock Spring Question / Steering Wheel Controls
- Po420 code and weird smell
- Rear Wiper Arm - Something Seems Off
- Shift Improver Kit
- Splash Guard Covering Oil Filter
- Clunk sound above 60 mph
- 2009 rx350 shifter console trim
- Free Fr Sway Bar
- MZOrange Tail Lights
- Drivers door rattle in 2007 RX350
- 2007 RX350 - Continual Check Engine Light Issues
- 2007 RX350 battery indicator shown on dashboard
- Phantom Aux Unit
- engine flush
- Rear Axle Rubbing Noise - HELP
- RX350 starting problem
- Panel?
- radio upgrade
- Eibach Pro-kit 2nd Gen Part # Confirmation
- RX350, steering wheel electronics
- silly question: How to unclip headlight wire connector?
- 2009 RX350 clunking front driver tire
- 05 RX330 Bank1/2 Cat Converter Swap
- Apple carplay - Grom or just get an add-on?
- Steering wheel lock not working?
- Sachs, KYB Shock Long Term Use
- Trans fluid topoff question, 2005 RX-330 AWD
- RX350 2008 chime doesn't stop when key removed.a
- 2005 RX330 Climate Control
- 22MM Addco Rear Sway & OE Front Bar
- Why, is my car stupid?
- Non-Interference Engine
- Parasitic drain on ECU-b fuse. 2005 RX330.
- Timing Belt
- 3.5” Dash Speakers DO NOT Fit! (Pioneer System)
- Toyota Techstream
- Key Fob Program
- Used RX Reccomendations
- Advice for buying 2nd generation RX?
- 2008 RX-350 Low Beam Bulb recommendation
- Programmed new key yesterday with Techstream and today it won't read any data from th
- Question about transmission fluid change
- Easy "Fix" for a broken COP connector clip
- Power Door problem
- obd2 connector pinouts
- HID Bulb Dilemma
- Passenger side lower engine mount.
- ERROR 4 Fault Message
- Where does this go?
- Scary Stall Out Question
- Oil Level Warning?
- Ac condenser other model cross compatibility with rx330
- driver window swtich not working proper.
- 2007-2009 RX350 Power Steering Pump Experiment
- Rx400H Steering Rack Bushes replacement
- Eibach spring availability?
- Rear diff and front diff fluid type.
- Close Call!
- Shock Cross Reference For Better Parts
- spare tire carrier
- Air conditoner failing
- Poly Control Arm Bushings
- Rear Liftgate Stuck Open Please Help
- window track replacement
- Water pump & Belt
- Steering wheel vibrating when braking at high speed
- Suddenly no crank ...
- New Low-Beam Headlight Replacement Issues
- ac vents increase air flow with acceleration
- Idler Pulley Rear Washer ?
- Removing the u151f from the top/front of an rx350
- Inspection fail
- 2007 RX350 - adding Blind Spot Monitoring system
- cruise control does not turn on
- Removing #1 Engine Bracket Secret
- 2008 RX400h - How can I remove passenger side interior panel (be feet)
- Index of Washable / Reuseable Air Filters
- Wrong spark plugs??
- How to change the high beam blubs and going to LED
- Driver door panel removal
- 2005 RX330 Brake lights
- Front Wiper Linkage Bushings/Nut Missing
- Where to get complete (with springs) brand new KYB rear struts for 2007 RX350 rear
- 2004 RX 330 battery drain
- Right Bank (Rear) VVti Solid Line Banjo fitting Washers
- RX330 Timing belt replacement: miles vs. time
- Aisin Water Pump Quality VS Toyota/Lexus
- Toyota Harrier magazines and catalogues
- Driver Door Making Clicking Noise
- Changing Door Switch Lights DIY
- Rear Door Panel Armrest Replacement DIY
- Upsizing Tire on OEM 18" Wheel
- Climate system diagnostics—error “42”
- Got a question about upsizing/downsizing tires
- 2005 rx rack and pinon
- Push button start conversion?
- Volume button not working on 2006 rx350
- 2016-2022 FloorMats Compatability
- Panning to install a touch screen Bluetooth head unit in a model with Backseat DVD
- I Can't turn the damn key!
- Engine /VSC light on
- dash difference ??
- Cabin air filter replacement help
- Exact length of rx330 hood latch cable?
- air bag stays on
- Ac not cooling
- Deer vs RX 350 Pebble Beach Edition
- 07 rx 350 stolen
- Water Intrusion
- Front windshield sprayer not working
- 2004 RX330 alignment specs
- Footwell Lights - 2009 RX350
- 2007 Lexus RX350 Fog Light Dashlight
- When do you stop putting money into your 2nd Gen RX350?
- Marker Light Differences
- 2009 RX350 AWD - Daily driver refresh project
- 09’ RX 350 new wheel advice/help
- rear taillight replacement 04 RX 330
- Drivers mirror and motor, 400h, 2008
- Speaker upgrade for '08 RX350
- Oem abs sensors ??
- Enigne Code P0717 P0793- Car will not move in gear
- Radio upgrade
- 2007 Lexus RX 350 Speaker Replacement
- Wheel colors
- 200,000 mile club
- Lower Control Arm Bushings Are Shot
- Electric issues?
- Noise from electronics behind rear seats 2009 RX350
- help repairing crankshaft sensor connector
- 2205 Rx330 won't start, blinking dashboard lights and clicking sounds
- When I'm not here,you'll find me at the cluhhouse!
- Transmission Slips in Cold
- Another "Cranks, but no start" for 2004 RX330....
- Dashboard lights don’t go dim when headlights are on
- Anybody Know What This Goes To?
- 04 RX330 side mirror issues
- Motor Mount Questions
- Difference between GSU30 and GSU35?
- What's that thing just above the right/upper side of the oil cooler line?
- Heat Max, Output Cold Max
- Awd tire replacement query
- Adding CARPLAY to Lexus
- Anyone got a line on a hood latch cable for $20-30?
- Traction control comes on briefly
- Cracks in dashboard
- 04 RX 330 headlights replacement
- Tape deck - phone mount?
- Side view mirror - bubbles under glass
- Helicoil transmission pan bolts with the pan still on
- Engine air filter/box...never seals?
- Normal operating temperature?
- Differentiating the location of a coolant leak and dealing with atf pan drip
- finally got an error code for my warning lights: P0356
- Vvt screen filter on 3.5??
- Which oil do you use in winter?
- Amplifier replacement
- Replacing side view mirrors
- Cover Next To Engine
- New to me(inherited 2008 RX350
- Cruise Control won't turn on
- Pcv hose replacement? Is it bad?
- 2008 Rx 350 Rip
- Colder weather & car "drone" on startup!
- 3MZ-FE engine Valve Cover Gasket replacement
- Gearshift Getting Stuck in Park - Changed Fuse(s) and now...
- OK to drive with all TPMS sensors went out?
- Engine Temperature and Heater Fluctuations
- Car won’t start but battery is good - bad starter?
- Battery issues / Potential short in wiring harness on ECU-b and Dome circuits
- Windows stay off after car is off... Ugh, it's back.
- obd2 scanner with customization option - Carista?
- the solution: How to reset the VSC Trac Off, Check Engine lights on my 2009 RX ...
- Afs off
- Did I ruin my car?!
- Radiator question
- Cant find Leaking trans line replacement?any ideas ?
- 2075b lock cylinder rod
- Rx330 Cranking But Not Starting When Hot
- Help!! Possible blown head gasket
- 2008 RX350 - Does Techstream work for Tire Pressure? On Android?
- TPMS ECU part number
- 05 RX330 Leaking Coolant Near Oil Filter
- 09 clicking, possibly dead, won't unlock AT ALL
- Exhaust Gasket Replacement DIY
- 2007 RX 350 Oil Cooler
- RX Heated Steering Wheel Project (2004-2009 models - 2016-2022 wheel)
