2016-2022 FloorMats Compatability
Old Jan 30, 2023 | 10:01 AM
HaryGahtoe's Avatar
HaryGahtoe
Default 2016-2022 FloorMats Compatability
Having difficulties with finding All Weather floor mats with 1 piece rear section and found a set stating that 2016-22 floor mats fit. I have not been able to prove/disprove the 4th Gen chassis was not a swap fit but Toyota shares alot of existing parts.
Just for the record, I have owned WeatherTech and the tall Bat wing edges tend to droop and catch stuff causing stains so although they're a nice set, I prefer the Factory style All Weather.
https://www.ebay.com/itm/38498049951...Bk9SR8iG4_a_YQ
Anybody with insight on 3rd & 4th Gen All Weather floor mats compatability would definitely welcome replies
Thanks
Old Jan 30, 2023 | 10:18 AM
meown's Avatar
meown
I have the 4th gen carpeted floor mats that I test fit in my 2RX, they fit the width across fine but the part under the center console needed to be wedged under there and it lifts up a bit right in the middle by the seat. I'd expect the all-weathers would need to trim that lip off under the console and it wouldn't sit flat in the middle.
Old Jan 30, 2023 | 10:23 AM
Rx330fnboi's Avatar
Rx330fnboi
close enough for government work
Old Jan 30, 2023 | 01:01 PM
HaryGahtoe's Avatar
HaryGahtoe
That would work.
I have a set of rubberized mats and they don't cover the center raised tunnel section at all and want something to cover the whole area but two that cover up the center would work
Thanks for the reply
Hary
Old Jan 30, 2023 | 01:48 PM
MattRX's Avatar
MattRX
2008-2013 Highlander rear ones are a good fit too, I tried 2014-2019 though and it wasn’t a good fit around the seats.
Old Jan 31, 2023 | 05:58 AM
dm87's Avatar
dm87
Default 2007-2009 RX350 all seasoned floor mats
Greetings, I wanted to make sure I was understanding the post. I have a 2nd gen RX350 2007-2009. And I've been looking for all weather floor mats with the lexus RX logo preferably brown. From the previous post are we saying the 2016-2022 all weather floor mats will fit ? I saw link on ebay that was posted for the black ones and it says they will fit. https://www.ebay.com/itm/384980499517?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=qvcvvhpcqt2&sssrc=2349624&ssuid=NXb3ioQ1S6q&var=&widget_ver=artemis&media=COPY I also saw this listing but it says it doesn't fit. Please help. Thank you
​​​​​​​https://www.ebay.com/itm/113300831070?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=8ztxzL1sSoe&sssrc=2349624&ssuid=NXb3ioQ1S6q&var=&widget_ver=artemis&media=COPY
All seasoned floor mats
Old Jan 31, 2023 | 09:57 AM
HaryGahtoe's Avatar
HaryGahtoe
Seller on eBay hasn't replied to 2nd request of fitment on the listing above
The actual measurements aren't available either so I'm not sure RX 2022 floor mats work especially the single rear will fit better than a Highlander or even a Rav4
*Update; Email reply from Lexus eBay seller
Quote
" Hello, Unfortunately it would not fit. The part number for the ones that would fit is PT908-48060-14 however they have been discontinued by Lexus. If you type that part number in google or ebay you may be able to find someone selling some used ones, but I wouldn't be able to get them. However, these are also a 4 piece set so if you are looking for the style that is one complete mat for the back, aftermarket will probably be the best way."
I'm grateful for the reply but the reason for searching out floormats was to get a 1 piece rear so aftermarket it is.
The only way to reach a solution would be to just ask a Toyota/Lexus parts rep to try a set for fitment at the lot.
Old Feb 3, 2023 | 02:28 AM
dm87's Avatar
dm87
Default All season floor mats
Thank you for the reply.
Will the floor mats reference in black fit a 2007-2009 RX350? https://www.ebay.com/itm/38498049951...Bk9SR8iG4_a_YQ
Originally Posted by HaryGahtoe
Seller on eBay hasn't replied to 2nd request of fitment on the listing aboveThe actual measurements aren't available either so I'm not sure RX 2022 floor mats work especially the single rear will fit better than a Highlander or even a Rav4*Update; Email reply from Lexus eBay sellerQuote" Hello, Unfortunately it would not fit. The part number for the ones that would fit is PT908-48060-14 however they have been discontinued by Lexus. If you type that part number in google or ebay you may be able to find someone selling some used ones, but I wouldn't be able to get them. However, these are also a 4 piece set so if you are looking for the style that is one complete mat for the back, aftermarket will probably be the best way."I'm grateful for the reply but the reason for searching out floormats was to get a 1 piece rear so aftermarket it is. The only way to reach a solution would be to just ask a Toyota/Lexus parts rep to try a set for fitment at the lot.
Old Feb 3, 2023 | 07:58 AM
Silva527's Avatar
Silva527
If you punch in your vehicle info, it states it will fit. The one thing I question though if you search the part number provided in the ebay post the photos show a 2 piece set for the rears not one full piece as shown in the ebay post. Also, since the center console slides to the rear I imagine the 1 piece rear prohibits the console from sliding back.
If you don't plan to purchase this set, let me know as I may look at buying it.
Thanks,
Old Feb 3, 2023 | 08:27 AM
dm87's Avatar
dm87
Default All weather floor mats
Thanks again for the reply. I have contacted the seller on ebay and it says they are on vacation. However, if you want to purchase them you can. I see other sellers who are selling (2016-2022) all weather floor mats and have reached out to them. Some are used and lower cost. If (2016-2022) will fit my SUV then I can search for those. As far as the one piece floor mat in the back currently I have a aftermarket that does not have the Lexus logo and I'm able to slide the middle console back over the floor mat it only gets caught a little bit. But it will slide. QUOTE=Silva527;11442352]If you punch in your vehicle info, it states it will fit. The one thing I question though if you search the part number provided in the ebay post the photos show a 2 piece set for the rears not one full piece as shown in the ebay post. Also, since the center console slides to the rear I imagine the 1 piece rear prohibits the console from sliding back. If you don't plan to purchase this set, let me know as I may look at buying it. Thanks,[/QUOTE]
Old Feb 3, 2023 | 08:42 AM
Silva527's Avatar
Silva527
[/QUOTE]
Thanks dm87. I too purchased an aftermarket 1 piece for the rear but it completely prevented the console from sliding back. I ended up cutting in half, but would prefer a full piece that doesn't obstruct the console from sliding.
Old Feb 3, 2023 | 12:37 PM
Silva527's Avatar
Silva527
[/QUOTE]
dm87, just an FYI I didn't purchase the set in the link you sent but found another and just purchased. I'll see how they workout in my 2009. Good luck on your search and hope these work out for you.
Old Feb 4, 2023 | 09:31 AM
dm87's Avatar
dm87
Default All seasoned floor mats
Silva527
I contacted the merchant on ebay who was selling the mats listed here https://www.ebay.com/itm/38498049951...mis&media=COPY
They ask for my VIN# and just replied saying "Hi, After checking the VIN, we found this item not suitable for your vehicle.Have a great day, and thank you for contacting us!" Although it says they do when I enter the make, model, and year of my vehicle. If you purchase the same year and style I would like to know if they work for your vehicle. Please keep me posed. Thank you. dm87, just an FYI I didn't purchase the set in the link you sent but found another and just purchased. I'll see how they workout in my 2009. Good luck on your search and hope these work out for you.[/QUOTE]​​​​​​​
Old Feb 4, 2023 | 10:06 AM
Silva527's Avatar
Silva527
Silva527
[/QUOTE]
Hi dm87, I too punched in my 2009 RX350 in the same ebay posting and it came up as "green" and compatible. The set I purchased was private party used and only indicated 2016-2022, didn't give the option to check fitment. So I guess I will see. I am supposed to receive next week.
Old Feb 4, 2023 | 12:52 PM
HaryGahtoe's Avatar
HaryGahtoe
Hi dm87, I too punched in my 2009 RX350 in the same ebay posting and it came up as "green" and compatible. The set I purchased was private party used and only indicated 2016-2022, didn't give the option to check fitment. So I guess I will see. I am supposed to receive next week.[/QUOTE]
Exactly why I posted this here. I was after the 3 pc. set (single rear covering both sides) and weather a later model fits or not I can't say with any certainty but the listings for all 2nd Gen all weather 3 pc sets are discontinued
I sent 3 msgs that Seller listed without an answer. I was even asked for a VIN, not before asking twice for a specific fitment for 2004-2009 RX350 2nd gen. Here's what I got for a final reply
Quote
"Hello, After checking the VIN, we found this item is not suitable for your vehicle.
Have an excellent day, and thank you for contacting us!"
