Rear diff and front diff fluid type.
Old Feb 21, 2023 | 06:36 PM
Paul17's Avatar
Paul17
10th Gear
Default Rear diff and front diff fluid type.
Hi all
i got a 2009 lexus rx350 and im not sure what type of fluid it takes in the rear and front diff
the front diff the drain plug says 85w90 i did find a bottle its from liq molly but doesnt say if its syth or not
Every auto store i look at they say 75w90 is it safe to put that in?? Its fully syth
Old Feb 21, 2023 | 06:59 PM
MattRX's Avatar
MattRX
Factory fill is 85W90 1L in front t-case and rear diff. I have been running 75W90 synthetic GL-5 in both for years (2002 Highlander and 2014 RX350) with no issue. Comes out real clean too.
Old Feb 21, 2023 | 07:21 PM
Paul17's Avatar
Paul17
10th Gear
ok thank you.
I dont think the 85w90 is syn
And i would like it to be syn so im gonna use the 75w90
Old Feb 21, 2023 | 07:34 PM
MattRX's Avatar
MattRX
1+ synthetic for sure! I have run syn DEX 6 in my power steering for years and it comes out cleaner too. Less resistance and noise from the system on cold starts too. Probably benefits us Canadians more than most where it gets colder. The original diff oil was pretty thick and didn't flow well when I tried to drain it cold.
Old Feb 21, 2023 | 07:43 PM
Paul17's Avatar
Paul17
10th Gear
Awesome thank you!
Old Feb 22, 2023 | 06:32 AM
Paul17's Avatar
Paul17
10th Gear
hey matt
do i need redline 75w90 NS or just the regular 75w90 it gives me to options.
Old Feb 22, 2023 | 06:58 AM
MattRX's Avatar
MattRX
I used regular Redline. NS “Non-Slip” is mainly for manual trannys to slow down synchros, it doesn’t have the friction modifiers the regular stuff has. However, I bet it would still work great in our diffs or t-cases.
Old Feb 22, 2023 | 09:43 AM
iMSQ's Avatar
iMSQ
https://www.clublexus.com/forums/rx-...l#post11363307
Old Feb 22, 2023 | 12:01 PM
Paul17's Avatar
Paul17
10th Gear
thank you I ended up getting
redline 75w90 NS (non lsd) full synthetic
due to supply i couldn't find the normal redline 75w90
hopefully the redline 75w90 NS full synthetic doesn't cause an issues.
from my understanding the car does not have LSD so should be fine. we will see lol...
thx for the help mate.
Old Feb 22, 2023 | 03:32 PM
MattRX's Avatar
MattRX
Should be fine. These cars never had LSDs, but a 99-00 RX300 limited slip rear diff can be fitted. That’s a mechanical (Torsen T2) diff, so it still doesn’t require LSD oil as there are no clutch packs.
I just checked my Amazon history and I did actually accidentally get NS and put it in over a year ago in my t-case. It has been a lot smoother than the original black, burned fluid and is as quiet as can be. I wouldn’t worry about running NS in our cars.
Old Feb 22, 2023 | 06:40 PM
Paul17's Avatar
Paul17
10th Gear
thx mattrx for your assistance much appreciated!
professorm
Feb 17, 2022 12:14 PM
lxus2001
RX - 1st Gen (1999-2003)
Jul 28, 2019 05:24 PM
wes77
RX - 3rd Gen (2010-2015)
Sep 30, 2011 06:57 AM
PhantomZX
Maintenance
Oct 22, 2003 01:24 PM
