Rear Wiper Arm - Something Seems Off
Old Mar 25, 2023 | 02:34 PM
MattRX's Avatar
MattRX
Default Rear Wiper Arm - Something Seems Off
I have a Japan-built 2008 RX350 and would appreciate everyone's input on this. On every Toyota I have changed the rear wiper on, the blade either comes up, or the plastic tab can be removed (or even modified) from the rear of the arm to allow it to extend out to change the wiper insert. On every RX350 video I have seen, this is the case as well. However, I do notice that the Japan-made RX incl all 400h have a different part number for the plastic cover and arm compared to Canadian-made models. My rear wiper arm also looks different than anyone I've seen. Do I have an aftermarket arm? I ended up having to remove the wiper blade from the motor's shaft using a gear puller. Not a hard or time-consuming task, but surely there has to be a better way than this!
Even with the plastic cover removed, there is a big piece of metal in the way that prevents the arm from tilting
The cover
Maximum range of movement that the wiper arm will allow, this can't be right!
Old Mar 25, 2023 | 02:57 PM
I googled 85241-0E010
inconclusive
Old Mar 25, 2023 | 03:04 PM
MattRX's Avatar
MattRX
Both 85241-48050 (Japan-made - the one spec'd for my car) and 85241-0E010 (Canadian-made) appear to be the same and correct for the application. Previous owner(s) probably swapped out the rear wiper with aftermarket or from another car. Not surprised because of the history of this car. This is probably one of the last few "kinks" I need to straighten out.
Circled area is completely different than mine
Old Mar 25, 2023 | 03:10 PM
This is the probably the cheapest you'll find
https://www.amayama.com/en/part/toyota/8524148050
Old Mar 25, 2023 | 03:13 PM
MattRX's Avatar
MattRX
Thank you, I'll be going with that if I can't find one in a junkyard soon
Old Mar 25, 2023 | 03:27 PM
meown's Avatar
meown
that's the range the wiper should ahve when that cover is on still. I have a similar issue, there's a plastic tab that goes into the grove where the blue lines intersect in matt's picture, it's supposed to be attached to the cover piece. On mine, the tab broke off in there and limits the movement by the same amount unless I use a tool to pry the small plastic out.
Old Mar 25, 2023 | 04:23 PM
MattRX's Avatar
MattRX
That's what I thought it was at first, but surprisingly that big darn piece in the way is actually metal and molded to the arm! I even tried to find a way to cut it off when I had the blade off the car, but there isn't an easy way to do it without destroying it.
Old Mar 25, 2023 | 08:34 PM
cfh13427's Avatar
cfh13427
The cover
That's All the movement that I have on the rear wiper blade on my 2005 RX330!
Old Mar 25, 2023 | 08:59 PM
joedaddy1's Avatar
joedaddy1
You can tell if the arm is aftermarket if you take it off and see if the hole has “teeth.”
teeth = oem
no teeth = chinese
Old Mar 25, 2023 | 09:13 PM
Don't try and remove without a wiper arm puller. Well unless it basically falls off.
Old Mar 25, 2023 | 11:22 PM
joedaddy1's Avatar
joedaddy1
hmmm.. have you ever pushed down (towards the window) on the windshield wiper hinges? That usually straightens out the hole to the bolt and allows for a pull/adjustment to the wiper. It’s a bit weird. You have to push down on the hinge with one hand and pull or adjust with the other.
Try that sometimes.. may save you a trip ha
TommyTT
Hybrid Technology
Jan 9, 2023 10:16 PM
Grumpa72
Jun 12, 2022 05:52 PM
LivinLarge
GX - 1st Gen (2003-2009)
Oct 26, 2016 06:20 PM
swammie
Nov 4, 2015 07:47 AM
cmstahl
Feb 3, 2004 12:00 AM
