Key Fob Program
Old Mar 4, 2023 | 08:51 PM
HaryGahtoe's Avatar
HaryGahtoe
Default Key Fob Program
I have a 2007 RX and while I was doing repairs I pulled the battery which took out the remote memory. I tried to follow two YT videos to program the door lock buttons. Neither worked.
Anyone who has used a repeatable Key Fob reprogram sequence I’d appreciate really the heads up
Thanks
Hary
Old Mar 5, 2023 | 01:28 AM
IntrinoX's Avatar
IntrinoX
Do you have Techstream by any chance?
Old Mar 5, 2023 | 10:52 AM
HaryGahtoe's Avatar
HaryGahtoe
I just got the car a few weeks ago so I’m looking into buying a Techstream system but no I don’t have one yet. I’ve read the the background and personal issue is all my systems are Mac so l’m going to have pick up a Windows based OS.
Old Mar 5, 2023 | 08:39 PM
IntrinoX's Avatar
IntrinoX
The other viable option would be buying a key and having a local locksmith program it for you.
Old Mar 6, 2023 | 11:01 AM
HaryGahtoe's Avatar
HaryGahtoe
The key isn't the problem. It was working. I'd replaced the key fob battery 3 weeks earlier and all functions worked perfectly. The key fob remote functions worked fine before I pulled the Cars main battery cable due to lengthy repairs needed.
So re initialing the fob with car "should" make the fob workable again it's just that the YT video procedure somehow didn't get the car in the learning mode to accept the fob remote button actions or I missed something. That's more to the point of what I need to find;
Key Fob Learning mode for a 2007 RX350 procedure
Old Mar 6, 2023 | 07:02 PM
DennisMik's Avatar
DennisMik
RX 350 Key Fob Programming
Programming Procedure #21485
1. Drivers door open, all other doors closed, key removed from ignition switch.
2. Within 5 seconds insert and remove the key from the ignition switch twice.
3. Within 40 seconds close and open driver's door twice.
4. Insert and remove the key from the ignition switch.
5. Within 40 seconds close and open driver's door twice.
6. Insert the key into the ignition switch and close the driver's door.
7. Switch ignition on and off,
a) Once to program a remote transmitter code while retaining the original codes.
b) Twice to program a remote transmitter code while erasing the original codes.
c) Three times to check how many remote transmitters are currently registered.
d) Five times to erase all registered codes.
8. Remove key from ignition switch.
9. System should now lock and unlock vehicle. Once, twice or five times depending which mode has been selected. One to four times, slowly, to indicate number of remote transmitters registered.
10. Within 40 seconds press and hold lock and unlock key remote transmitter buttons, together, for 1.5 seconds.
11. Within 3 seconds press any key remote transmitter button.
12. System should now lock and unlock vehicle. Once to confirm registration, or twice to indicate registration has failed.
13. Within 40 seconds repeat steps 11 and 12 to program remaining remote transmitters.
***** To exit programming mode: Open driver's door or insert ignition key.
***** A maximum of 4 key remote transmitters can be programmed.
Old Mar 7, 2023 | 09:59 AM
HaryGahtoe's Avatar
HaryGahtoe
Thank you for the post DennisMik
Due to the videos I was guided slightly different in two different stages and I'll try the listed fob learning procedure asap.
I'll let you know the results either way shortly
I appreciate the help.
Hary
Old Mar 7, 2023 | 01:31 PM
HaryGahtoe's Avatar
HaryGahtoe
I tried the procedure using both keys simultaneously and it worked. The car accepted both and both sets of remote key fob buttons work
Thanks again DennisMik
Hary
Old May 20, 2023 | 01:26 AM
Missin10mm's Avatar
Missin10mm
Is this used for programming a completely new transponder?
Old May 21, 2023 | 04:21 PM
DennisMik's Avatar
DennisMik
Not sure what you mean by "transponder". The procedure will program a key fob (new or otherwise) to open & lock the doors. The chip in the key that allows you to start the car is not programmed into the car's computer with this procedure.
Old May 22, 2023 | 07:26 AM
slwortham's Avatar
slwortham
5th Gear
Will this sequence work for a 2004 RX330?
Old May 22, 2023 | 10:59 AM
DennisMik's Avatar
DennisMik
The procedure is for the 2nd gen RX, so it should.
Old Jul 6, 2023 | 08:45 PM
Lisa23's Avatar
Lisa23
3rd Gear
I followed these steps, but at step 9, my vehicle didn't do the lock and unlock cycle. Do you know why this happen? Is there any suggestion on what I should do?
Old Jul 6, 2023 | 11:57 PM
DennisMik's Avatar
DennisMik
I don't know why the procedure failed step 9. I wonder if you already have 4 other key fobs programmed to your car. Toyota only allows 4 key fobs and a 5th one would br ignored. You could try step 7c which is to find out how many key fobs are currently programmed to your car. If you do have 4 already, then you will have to erase all the current key fobs (step 7b) and then program in only the ones you want.
Old Jul 7, 2023 | 09:35 PM
Lisa23's Avatar
Lisa23
3rd Gear
But I successfully program the immobilize for that key. And I can use it to start the car. I just couldn't get the remote work. So I don't think it's because the car had reached its maximum key, right???
