Tire Pressure Blinking
Old Apr 25, 2023 | 08:00 AM
mudoy's Avatar
mudoy
2nd gear
Default Tire Pressure Blinking
Hello!
I am facing an issue with my 2004 RX330. After driving for nearly an hour, the tire pressure light starts blinking on the dash and some other lights come together (BRAKE, ABS, VSC, Trac off). Then if I stop the engine and restart, all those lights go off and I can drive again for nearly an hour without those warning lights. This cycle repeats and not always do those lights come exactly after driving one hour, sometimes they come once a day. I have checked the tire pressure, which is alright. The tail red lights also glow without any issue when I press the brake paddle. Could anyone please guide me on how to solve this problem? Thank you so much.
Old Apr 25, 2023 | 10:37 AM
iMSQ's Avatar
iMSQ
Do you have tire pressure sensors? Check/replace them. They have a finite lifetime.
Old Apr 26, 2023 | 12:39 PM
Felix's Avatar
Felix
Originally Posted by mudoy
Hello!
Happened to me a couple yrs ago......You'll have to go to a tire shop, aka Discount tires & have them figure out which ones need replacing...I ended up have 3 replaced & btw the spare has on as well. Check all the tire pressures making sure the lbs is up to what you have the set to tpms set to.
Old Apr 27, 2023 | 06:18 PM
cfh13427's Avatar
cfh13427
The '04 RX330 doesn't usually come with TPMS sensors.
They use the ABS Wheel Speed Sensors to detect a tire that is Under/Over Inflated.
When a tire is Over Inflated or Under Inflated, the tire diameter changes, and the Wheel Revolutions change, setting off the Warning Light.
You might want to have your ABS Wheel Speed Sensors checked.
Old Apr 29, 2023 | 07:52 PM
Felix's Avatar
Felix
One look at thhe tire valve stem will tell you.......
Old Apr 29, 2023 | 08:28 PM
cfh13427's Avatar
cfh13427
That's Not Necessarily True!
Goldmasher
ES - 7th Gen (2019-2025)
May 24, 2021 07:46 PM
u7mg0
Oct 3, 2018 10:50 AM
jbonez89
Jul 31, 2016 03:07 PM
whatnext
Jul 31, 2015 05:55 PM
eeross23
Mar 24, 2014 02:24 PM
