Driver Door Making Clicking Noise
Old Feb 5, 2023 | 06:24 AM
Silva527's Avatar
Silva527
Default Driver Door Making Clicking Noise
Hello, the driver door on my 09 RX350 makes two clicking noises when open and closing. The door is not touching the fender. The other hinges do not seem loose in any way.I think I narrowed it down to this black piece (not sure of the correct part name). I can feel the black piece move up and down at the point of the clicks when opening and closing the door, not sure if this is normal. Before I take the panel off, I thought I'd ask if anyone else experienced this issue. Does this piece some how attach on the inside of the door panel as well? Does this piece fail and is it easy to replace?
Thank You,
Old Feb 7, 2023 | 10:05 AM
mandyfig's Avatar
mandyfig
There's only one way to find out, tear it down and see how it is attached to the pillar. Good luck.
Old Feb 7, 2023 | 04:10 PM
cfh13427's Avatar
cfh13427
Thank You,
It's called a "Door Check" by Lexus/Toyota and like the name, it keeps the door from opening too far, and also to help Keep the door Open.
It's Not that Hard to Replace, although it can be difficult to Access all of the Components.
Hopefully, You can Secure what's loose.
I think the part is over $100 from Lexus, You maybe able to find one at an Auto Parts Store or Ebay, etc.
Old Feb 8, 2023 | 08:31 AM
Silva527's Avatar
Silva527
Thanks cfh13427.
I may take the panel of this weekend in hopes of finding a loose bolt or something.
websurfer
24
Jan 27, 2026 01:36 PM
LouisV
NX - 1st Gen (2015-2021)
Apr 2, 2019 07:05 AM
jd93
Feb 26, 2017 03:48 PM
zachisf14
Nov 21, 2016 06:28 PM
