- Is this normal for is250 wheels?
- Steering Problems On Freeway Help Please
- DRL Full Power
- What a horrible situation =(
- Sunroof issue
- Genicolor paint pen?
- Dangerous steering important!
- Need high mileage tires for IS250rwd with 18" wheel package
- 2010 IS250 AWD Issue
- is250 awd road magnets springs !
- is250 awd road magnets best place 2 buy ?
- '08 IS250 front subframe splash guard mounting point broke off
- Help needed: Part number for rear tow hook cover?
- Replacing my spark plugs this weekend on my is350
- My loaded 2012 headlights on the way... ?'s
- Just another average IS350
- programming seats
- Engine shake at start up
- Average MPG on is350s??
- Oil Filter Change: What tool to open up the bolt that lead to the small o-ring?
- does anyone else do late night cruises to relieve stress?
- Finding an IS350 with Mark Levinson
- getting my is 350 soon i hope. need opinion on new wheels..
- Thinking about going from BMW to Lexus, need some info!
- dealer inspected my brakes today and....
- 2012 Headlights| Parking and Signal light bulb replacements?
- Dealer replace dash
- A little advice from the best car community i've seen... thanks in advance
- 2012 Lower headlights replacement?
- Is250 shifter gate does it light up ?
- Car downshifts into 5th on the freeway if I touch the brakes
- New Member: Tungsten Pearl is250
- Who still does LED conversions?
- Sewell Colored Grille Surround
- Lexy left me stranded on I75
- 60k miles maintenance on '07 is250?
- Accident/ Engine Kill Switch
- Ipod Nano not working in USB port
- Best setting for freeway throttle?
- Is bank 2 the driver side or passenger side?
- How do you fix scratched/gouged dashboard?
- Vibrations for the second time around. Carbon Build Up, again?
- HELP! My brakes are turning red!!
- Newbee here and I could really use your help please
- Fender Rolling 19x11 rears
- Should i paint or wrap my hood
- IS 250 (2007) navigation is not working: A programm cannot be read...
- Can I tell which color the car is by vin?
- My next trip!!
- How do you separate door panels (or tighten them)?
- 2012 HeadLight questions....
- IS250 Squeaky Driver Seat + TSB
- Rim Width! Will it fit?
- New IIHS Crash Test
- legit GFX kit? 06-08
- Did I get scammed by the dealer ??
- Do you guys have wheel locks on your aftermarket wheels?
- Got Pulled Over.. Need Some "Guidence"
- 60k
- Got a CEL scanned and I have a P0430 error code!
- Just purchased 09 Lexus IS250 with regrets - HELP
- IS250 Headlight
- Who has had dealer replace complete NAV unit out of warranty?
- Just changed my drl bulb to led and when i went to put it in the housing it stops wor
- Does my Lexus 2012 IS250 come with HID?
- HELP! Very loud rattling sound from clutch area & car struggles to get into 1st
- How do you eject NAV disk without the touchscreen working?
- is350 power window.
- Side Branch Resonators: Drone Cured?
- Clutch Replacement
- Wald lip kit install pointers
- Aftermarket or DIY keyfob
- HELP HID Fog light problem
- Removing burn mark
- Sqeaks solution please
- Need Some Advice
- Invidia Mid Pipes + Stock Exhaust.
- Anyone use putco fog lights (night white)
- While doing exhaust work
- S mode auto shift?
- JLC Plama LED Turn Signal Lights
- Please help with vin!!
- Invidia Mid-Pipe install help?
- Need help being flush!
- pics- ISbrothers
- Goodbye IS 250C.... Hello IS 350C :)
- ML speakers
- Is it possible2sweep the streets w/0 a front lip? Vid inside
- New IS350 F-Sport
- 2009 lexus is250
- 2008 IS 250 AFS problem?
- Need help with replacing bearing. 06 is350
- Lights connected to battery wont turn off! Help if you can
- CF front lip from Sonicmotor
- How many miles/year?
- Oil maintenance warning
- My new beater!
- Just picked up a 2010 IS250
- steering wheel problem 2012
- Is it safe to have two lexus keys in one car?
- Please help with this noise (Video)
- Not a good start to owning my first lexus!
- Need opinion on cost of a custom paint job
- MyRide Diffuser! Advice Needed!
- Wheel specs help
- Throttle response and sport seats?
- My custom paint tail lights
- Stages Of My Car
- are all 2010-2012 IS350C the same,any year better than another?
- low oil pressure vs level
- Somewhat of a scare
- Tinter damaged my demister
- New here...clutch problems?
- is250 stock lip
- Fairwell IS350
- 08 IS250 AWD just cleared 100,000 miles - any maintenance needed?
- 2006 lexus is 250 HORN problems replace the clock spring
- Ignition Button
- Need Help, wife hit a curb pretty bad
- What psi are you running on your tires
- Introduction-- Hello From SouthEast Kansas
- Package Options on 2nd Gen IS
- How to disable tire sensors?
- UMcanes introduction from Miami
- Need advise for buying a used car 2009.
- IS 250 eyelid covers and repainted upper grille
- SFFD103's photography thread
- Roadrover (Flyaudio Replica?)
- I bought these parking lights already would these fit ?
- Recirculation Always Switching Back On - Issue Resolved
- Are certain colors more expensive?
- 90K is350 problem,PLEASE HELP.....
- Horn not working replace clock spring
- Dealer put all fluids to Max line...
- *** Owners of 2011+ headlights and yellow fogs ***
- dash melting
- Spray tinit
- New member from the north!
- 2 week review of my 07 IS250
- Weird brake clicking noises in very low speeds and stops...
- PIC REQUEST for VISORS on SFP
- Finally done!
- Loud engine clanking noise
- IS250 to the 350 brake conversion...and stuff
- Noob question. How do I?......
- Tire pressure gauge
- 2009 fog lights
- NAV voice commands
- AWD Tire replacement
- Weird NAV screen problem. HELP
- 2012 LED headlights 100%-50% circuit.
- Suggestions on fog lights
- When did you have your waterpump replaced?
- 8k hids turn on then off
- New Member from Chicago
- 2012 IS250 Starfire Pearl Side Mirror Paint Mismatch
- Third member with IS300 Torsen LSD
- Purchasing Advice
- What wheels would look classy and nice on an IS?
- New from NM, set this up for the wife in training
- DIY: Engine Air Filter and Cabin Air Filter 2008 IS250
- Cracked my lip in half!
- New comer!!
- Not so helpful ISx50 owner
- im a newbie and I want to get tint on my car
- Purchasing FORGESTAR CF5 wheels; need tire help
- Car wont star HEELLLLL ME.
- Wald ISF Kit for an IS250/300/350
- Thinking about powder coat my wheels?
- New Navigation System in my 2008
- Selling the AWD IS350 :(
- Rear Axle Carrier (Knuckle) Bushing Replacement
- IS350 no electrical power. HELP!
- battery replacement question
- 75k service
- anyone have these tims on their car?
- racing chip...what do we know about this?
- DIY: iJDM DRL on IS250/350
- Video: Formula Drift Round 5 - Monroe, WA
- Guys that have changed out their headlights...
- Photographers wanted in NC
- Has anyone every had this much confusion when order a part on your car?
- new rear bumper? VIP rear cover (duraflex)
- New black wheels (20's), blacked out grill and exhaust tips. (IS250 AWD)
- Dented my trunk lid!! :(
- what is this plug.... help...
- Rear GFX, bottom part painted to look like a diffuser
- Has anyone else had problems installing HID bulbs
- New headlights - Thanks Sewell!
- Thanks to Sewell!
- Bad Morning
- Issues with my radio. No volume
- Mark Levinson Sound System hurt my ears
- Electrical problem! Helppp!
- New to the IS Club
- Trunk air setup with sub... Problematic or not?
- Did anyone use aftermarket Cabin air filter??
- Good deal on Lexus Certified Warranty
- 07 Lexus IS Headlight Issue
- F-Sport IS250 + Vossen CV7 + IPhone
- Maintenance
- Blinker Lever Maintenance
- Quad Exhaust + Rear Lip Installed This Weekend, What Spoiler To Go With?
- New GReddy's
- My IS250 AWD
- Flat Bottom Carbon Top Blue Stitch?
- 08 IS250 Rear Axle Seal leak fix?
- Reset windows now check engine and check system lights on
- bought an 08 is250 options not as listed. Now what?
- vertex front lip
- Wanting opinions/thoughts...
- Driver's side window controls won't work on passenger side windows
- Where are the is350 supercharged #'s???
- Clutch
- Spark Plug change question
- IS250 Sunroof Issue
- IS250 X-package wheels
- Has anyone tried these headlights instead of sewells?
- LED DRLs--moisture cover won't fit
- Lexus is250 Isf rims
- Looking for Audio Installation Place In Sac
- Occasional sputtering
- OEM staggered setup? WTF?
- locking issue!
- 55w hid in fogs?
- Thoughts on vinyl wrapping the whole car
- Dealer/Warranty Issue - Need your opinion
- HELP! HVAC evaporator drain blockage -VSA Warranty
- New shoes for my Lexy~
- How many mpg are you getting on your is350?
- Front lip installation? HELP!
- Doesn't look as bad as I thought.
- Newbie here with a noob question?
- recall? Insufficient Tightening of fuel pressure sensor
- which set of rims look the best on the car?
- IS250 VS. IS350 Reliability
- need help sunvisor light...
- Just replaced my sat screen, it works now!!!
- ★★★★★ Official ISS Forged Owners Thread ★★★★★
- I think i'm going to buy it, unless...
- Opinion from the AWD gurus?
- Car battery keeps dieing?
- is250 Vinyl rap how much is needed for the interior ?
- Braking Issue
- Front View Camera
- Any one out there running their wheels with out TPMS???
- Is it time for me to say goodbye to my 06IS250?
- 2011 is350 steering failure caused accident can anyone help.
- Found this in 9gag today
- Anyone know if these OBII bluetooth works for the 2IS?
