Both Of My Windows Dont Work Any More Everytime I Try To Roll The Window Switch Makes A Weird Noise I Never Encountered This Problem Before Please Help And If I Try To Roll The Pass Side No Response
I have a similar problem, but there are no noises. The passenger window will roll down only when i push the button on the driver side. It rolls up fine. Maybe the switch on the pass. side is defective?
I just started to have the problem on my Driver side, I rolled it down and i head a clunk and it wouldn't come up anymore.
I opened it up and the motor was working fine but it looks like the cable isn;t grabbing where it should. I just MacGyver it with Wood and Duct tape so it would stay up while I made sometime to take a look at it closer.
If the switches only work on one side but not the other, check and clean the switches. If your window only goes up or down but not both, it's the regulator.
My SC400 did that recently, both windows didn't work at all and the switch made a buzzing noise.
The dealer said I needed both regulators @ $795.00 ea.
I took it to a stereo/alarm guy and in 30 seconds with a continuity tester he found a dead ground, clipped it, reground in the door and shoop- both windows came up and down.
It is just a bad ground. I will look to see where he grounded and which wire.
