Swapping Key Internals?
Old Oct 6, 2007 | 09:18 PM
RedPhoenix's Avatar
RedPhoenix
Default Swapping Key Internals?
If I get a junkyard key for my SC, can i swap out the internals and the key portion into the new frame? My key has a broken keychain section, so without getting it reprgrammed, can i just swap my key internals?
matt
Old Oct 7, 2007 | 12:16 AM
habitat's Avatar
habitat
This should be 100% possible with a <95 key. I have a 93 sc and I had to open it up to replace the battery. The pc board removes completely from the key so it would just be a simple swap! Someone else can confirm the newer model keys....
Old Oct 7, 2007 | 12:29 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
one or the other, not both.
Old Oct 7, 2007 | 08:04 PM
RedPhoenix's Avatar
RedPhoenix
so they key only or the chip, not both? any reason why?
Old Oct 7, 2007 | 08:07 PM
habitat's Avatar
habitat
I reread your original post and now i understand what OLT meant, the pc board is swappable not the key. Your best bet is to swap the pc board, into a new uncut key, and recut it.
Old Oct 7, 2007 | 08:33 PM
RedPhoenix's Avatar
RedPhoenix
ahh.. thats crappy. i wonder why?
oh well, if it has to be done...
Old Dec 13, 2007 | 08:38 PM
phinicben's Avatar
phinicben
Default swapping internals and chip from the remote receiver ecu
DId swapping the internal into you key work? Did swapping the chip with another chip and matching key work? I found a 92 LS400 wrecked, with the key in the ignition(key with one button on the side. I pulled the remote reciever from the truck, which had the same number as the ecu in my 92 sc400. I swapped the chips in the ecu, but it still doesnt work. Is there somehting i have to do to make it work, or will it work. I tried some of the programming techniques that i found from searching, but none of the seem to work. I do not have a master remote key, only a master non remote. does taht matter? Help anyone? would be nice to get the keyless working, but not at a great expense.
Old Dec 14, 2007 | 10:33 AM
tavarish's Avatar
tavarish
dremel and krazy glue ftw.
Old Dec 14, 2007 | 02:51 PM
sc250tt's Avatar
sc250tt
Its easy to swap internals .for the ignition all you have to do is press the little slug and pull the lock out . the hardest part will be ching the locks on the doorhandle.
avihi
Dec 4, 2018 05:48 PM
senapeSC
Mar 14, 2013 12:15 PM
21SF
Aug 16, 2012 01:38 PM
bandolero
Sep 18, 2009 07:53 PM
lok888
Sep 14, 2006 08:42 AM
