odd electrical problem
Old Oct 5, 2007 | 12:25 PM
roxanne's Avatar
roxanne
Default odd electrical problem
I took my steering wheel off to fix an alignment problem, and when I put everything back together all hell broke loose. My cruise control light won't come on and won't work, my horn won't work (alarm horn still works), and my SRS airbag light won't go off. I've checked all the fuses and checked every wire and connection in detail with no found problems. Any ideas?
Old Oct 5, 2007 | 02:44 PM
xspsi6's Avatar
xspsi6
You may have damaged the clock spring?
Old Oct 5, 2007 | 02:58 PM
lexsc492's Avatar
lexsc492
there are points on the clockspring. you have to make sure its lined up before u replace the wheel.
Old Oct 5, 2007 | 05:20 PM
sc250tt's Avatar
sc250tt
yup damaged clock spring .it happened to my sc ,when you get a new one read the directions on it before installing it ,otherwise it will snap again.
Old Oct 5, 2007 | 11:23 PM
soarinhigh's Avatar
soarinhigh
I think you pissed your car off.
Old Oct 6, 2007 | 01:59 AM
jattunit24's Avatar
jattunit24
i had the same exact problem!. its so frustrating. i think im goin to change the clockspring.
Old Sep 22, 2008 | 02:29 AM
NiceSC400's Avatar
NiceSC400
What about having the airbag light on and a non functioning horn, BUT I did not do anything to my car? I checked all fuses and they all seem OK. I do think that the alarm horn still works.
Please help.
As a side note, my radio fuse will burn even with the radio completely disconnected, what could it be? This problem ocurred months ago, seems not to be related to the airbag/horn problem.
Old Sep 22, 2008 | 06:48 AM
19psi's Avatar
19psi
why didn't you just gt an alignment done to fix an alignment problem? otherwise, yes the clockspring is damaged if you already checked all the connections under the airbag for integrity.
lexsc492
May 9, 2013 06:08 PM
pwrdbyrice
Aug 20, 2008 10:50 AM
mrgotit
Jul 23, 2007 05:30 PM
minla007
Jun 13, 2007 07:15 PM
supercoupes
Nov 1, 2001 05:49 AM
