sc300 spring and shock combo advice
ok, before i get my head chewed off....i did search...yes i know how to use the search feature but i wasnt satisfied with what came up.
so, what do you guys recommend for a sping and shock combo? i read that the TT eibach springs drop lower than the sc springs, but that the eibachs tend to sag? are the tein s.tech's better than the eibachs? i want a comfy ride, but firm when cornering. i also want a look that is pretty even, not with the a$s in the air. i dont mind alittle difference in ride hight. Will i need a camber kit? just the front? or both from and rear? what is a good spring shock combo and for which car? sc or tt.
thanks alot for your help in advance.
john the newb.
thanks alot for your help in advance. john the newb.
SexyChick
Jul 7, 2007 11:42 AM
combo, good, guide, recommendation, sc300, schock, setup, setups, shock, spring, springs, springshock, stech, suspension, tein
