SAFCII Weird throttle issue
Subscribe
Jul 17, 2008 | 08:31 PM
so for some strange reason my throttle reading on my SAFC goes blank or it is reading very low, when i know for a fact that im at like 40% it'll tell me im at like 5 or 6%. I double check my connection to the ECU because i thought it was my wire taps so I soldered the connection but the same thing happens. does anyone know what the problem could be thanks!
Reply 0
Jul 18, 2008 | 12:15 PM
Try to calibrate your throttle settings. First go to "sensors check" and see if you're getting the proper signal, then go and calibrate your signal by leaving it closed for 10 seconds then depressing the pedal all the way down for another 10 seconds..
Reply 0
Subscribe
