why did they put so little caster? i would have run it up a lot more. camber numbers look good. sux for your tires but will be pretty good for handling.
yea fix that caster or the car will start to wander to the left a bit, but that might be offset by the high amount of positive camber on the right side. Better get those fixed.
A shop did it for me. They told me the negative camber wasn't to bad so they barely touched it. They said my toe before was way off. I was wondering shouldn't the caster be equal? I'm not to familiar with this stuff.
Could i use the Lance specs verbatim, as they are written on the MKIV site? I was planning on getting an alignment done soon. I have stock 97+ wheels on 225/40/16 tires, stock ride height.
