Rerouting Driver Side Harness
Old Jul 9, 2008 | 11:49 AM
JspecSC3's Avatar
JspecSC3
Default Rerouting Driver Side Harness
Im trying to reroute the wiring harness that is right underneath the driver side fender. I took a look yesterday and it looked like all I had to do was unplug a few connectors in the footwell by the clutch pedal and remove the 2 10mm bolts in the fenderwell. I then began to tug on it to see if I can get it out but there seemed to be another series of wires that ran right behind the fuse panel in the driver side footwell by the clutch pedal. Now my question is, how would I be able to get to this series of wires which is most likely attached to 1 connector? Ive already removed the 4 connectors attached to the harness but apparently I missed 1 more but cant really get to it. Any advice would help. Im tired of my tires cutting through the harness at every bump. Thanks!
Old Jul 10, 2008 | 01:07 PM
buffalosoj's Avatar
buffalosoj
I started to do this also, but what I did was get some additional wire loom and zip tie it above the lip in the fender well. I ride very low and haven't had any problems hitting that anymore. Not what you asked for, but just a suggestion.
Old Jul 10, 2008 | 07:12 PM
JspecSC3's Avatar
JspecSC3
I did that on my brother's SC. I just lowered his but not to a full slam yet. Still rubs while make a turn and hitting a dip at the same time. I'd try that myself but Im going to be going super low with my wheels pushed out. Im already stretching just to clear the rolled fender.
Chris18
Mar 12, 2014 11:28 AM
SynicalVip
Nov 27, 2012 09:55 PM
DvSiR
Jan 13, 2010 12:51 AM
txSCdrifta
Nov 26, 2008 06:55 AM
rpx13
Oct 15, 2008 10:17 AM
