Sponsored by: CARiD
what is the lightbulb size for shifter 98 gs4
Old Apr 29, 2009 | 10:50 AM
blkgs4wnav's Avatar
blkgs4wnav
Default what is the lightbulb size for shifter 98 gs4
what is the lightbulb size for 98 gs400?
Old Apr 29, 2009 | 12:21 PM
Debonair's Avatar
Debonair
Hello all (Links to most DIYs for the GS) PLEASE LOOK HERE BEFORE YOU SEARCH!!
Center console bulb replacement DIY:
https://www.clublexus.com/forums/gs-s...ator-bulb.html
Originally Posted by sakataj
AS A BONUS I DID THE TRANNY INDICATOR BULB WHILE I WAS IN THERE SINCE IT SEEMED DULL THE DIY IS BELOW
the bulb # is a 74. i ordered it from www.v-leds.com use the code club lexus for 15% discount. this is the bulb i used http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
****RIGHT NOW THEY ARE OUTTA STOCK ON THAT BULB WHICH IS WHY THE LINK DOESNT WORK.....U CAN USE THIS AS A REPLACEMENT
gear indicator
step 1:this is what you should see since you already have the console removed
step 2:carefully take a flathead and pry this bracket up CAREFULLY
step 3:carefully take a flathead and pry this bracket up CAREFULLY
step 4:carefully take a flathead and pry this bracket up CAREFULLY
step 5:carefully take a flathead and pry this bracket up CAREFULLY
step 6:bulb is in the housing to the left of the shifter with the green cover on it
step 7: just put bulb in, i chose to leave the green cover off for more light, reattach shifter console and put everything back together again
(as u can tell the light is bright its shining out the side of the shifter)
vadorade
Nov 7, 2017 07:43 PM
yllwneck86
May 9, 2016 08:45 AM
silvaIS
Apr 25, 2012 06:20 AM
LexPaul
14
Apr 9, 2012 04:09 PM
Altec914
Mar 4, 2008 06:25 PM
