- Sc door chime?
- starter replacement.
- Fuse box access
- Need help with walbro 255 getting stuck.
- Can i use w58 from a 300 in my 400 for 5speed swap?
- Battery Light.....
- Mines ECU
- Need Help want to MOD engine
- Engine ECU Facts
- Aftermarket cat's for sc300 california legal
- E85 help please
- Should I Buy a New Engine
- Roll Cage Benefits (or lack there of)
- '97 400 transmission
- Will the ls430 3.266 fit my sc300?
- sc400 single turbo mainifold idea what do you think
- Car shakes when downshift-5spd W58
- SC300 Front Seal - Lower gear puller?
- 92 sc300 idle issues
- Broken Exaust
- 98+ 5 speed swap. CEL code P1780
- TRAC OFF / Check engine
- 1.5JZ Code 55-rear knock sensor
- Any way to get rid of the egr in a sc400?
- Shift linkage
- I cant get my headlights out
- LSD in SC300?
- 1jz code 14 out of no where...ideas pls.
- SC400 Manual Swap Questions
- 92 sc400 will not start
- Timing
- Fuel Pump Relay with aftermarket setup
- Map ecu 3
- tt fuel pump help
- injector color and partnumber
- auto to manual swap on 97sc300
- School bus engine swap?
- Best way to get more power for my SC300 for under $1500?
- tallest gear ratio?
- Help understanding cams
- 97 sc300 exhaust
- picture request! 1jzgte injector wires
- AEM EPM instead of &M CPS???
- Dash fuse keeps blowing
- 97 sc400 high idle when cold issues??
- mk4 supra resistor pack wiring into 1jzgte
- Power steering leaks
- exhaust problems
- Treadstone Cast Manifold - 2JZGE NA-T- Anyone use it?
- Knock in drivetrain sounds like U joints
- Gte swap usdm harness?
- 2JZGE intake flapper valve thingy
- FIXED: Brake pedal & high beams kills stereo dims lights & stalls engine
- Diff change to 3.26
- sc400 won't rev past 4000 rpm
- Help with code 71
- went to smog my car and ran good till
- Shifter Shaking / Rattling. Possible Fix
- seafoaming the idle air control valve?
- R154 gurus: Front Retainer Plate cut...need new one?
- Car starts but wont stay running
- Torque Limited Frist gear 92 SC400
- Radiator help needed desperately
- SC400 OBD-I to OBD-II conversion project in progress... :(
- Any body make poly subframe and diff mounts?
- higher volume vs higher psi?
- Poor man's exhaust mod
- how much whp can 2jzge handle stock
- 1JZGTE Wiring Question
- Removing oil galley plugs?
- Sc300 2j R154 swap-Need drive shaft
- manual & auto driveshaft rubber doughnut interchangeable?
- Engine Replacement SC400
- Easiest bfi mod?
- Turbo Kit
- i think my transmission is going out please help
- Sc300 vs 400 rear diff ratios??
- Help please: No heat/defrost
- Weird radio issues with 1993 SC300
- SC ECU part numbers by model year, pls help?
- blew the efi fuse agian,
- starter circuit
- Anybody here have a 1j vvti swap completed?
- EGR valve cleaning
- In need of some power lol
- Best Spark Plug for SC400
- Need tech help with timing marks 3.0L
- 2JZ-GTE swapped engine not getting spark!
- Need advice from someone who knows about iacv & tps
- Map ECU 2/Tuning on a 1jz
- Need advice (and probably a motor)
- Belt Idler Pulley noise?
- Part II: Engine Upgrades: 2JZGTE T61 R154
- What are the odds?
- help please
- 1jz still has code 42 after ecu swap
- advice on intake/headers/exhaust
- Ran a new pb
- 1jz Power problem
- 1uzfe current supercharger options??
- No Code But no power
- Oil Pressure switch
- Turbo manifold for NA-T
- Parts interchangeable?
- Clutch recommedations?
- 92 Lexus SC400 no spark?? Help please
- 92 SC400 at Idle in park rpms 1500 to 2200
- PPE Headers & Custom Merge Collector
- Lower Temp. Thermostat not working?
- fmic with ac
- Reveiws on JDM Planet
- Are catch cans necessary with single turbo setups?
- Should I use this still????
- O/D light intermitent blinking on my dash? wtf ??
- Sparkplugs are drenched in oil
- Problems with diff changing to Supra LSD
- 02 sensor
- '99 SC300 Idle Vibration - Major Tune Up Recently Done
- R154 transmission issue
- Diagnostic Error Code - DTC 17
- some plans for my sc
- sc300 temp needle moving up and down
- The Clublexus Lessons Learned Performance Thread
- Driftshaft Woes! after 1jz swap (pics inside)
- Could current mods cause my car to be running rich?
- 1j to 2j....how should I do this
- BOTH doors on '95 SC300 won't open. Locked out, what do I do?
- Shimming transmission acumalators
- "performance" throttle body???
- Looking for Leather saet covers
- aem ems on vvti whos got one
- pte billet 5857...im in love
- How to check the fuel pump?
- Couple of Questions from a New SC300 Owner!!
- SAFC 2 rpm signal
- 99-00 EVAP stock location?
- 1995 Lexus Sc300 Coupe
- Another 2jzgte swap question.. please help!
- 92 SC 400 - Bad shudder at idle, ticking valves
- My sc300 has new catalytic converters
- Fun upgrades and parts that I recieved
- Fastest 1JZ stock turbo time and boost pressure
- 1JZ Starting issues
- Replacement Gauge Cluster?
- Sc400 Rear Main Seal Replacement
- I need help with an overheating issue
- TT Pump
- Aftermarket torque converters?
- quick help with gs400 rear end swap
- repaired powersteering, now it wont start
- AEM F/IC 1UZ. Is it worth installing while still N/A?
- Aftermarket Battery Replacement
- 93 sc300 1jz and auto to manual swap
- Replaced clutch slave cylinder pedal still sticks???!!!?!?
- Missing Vac lines
- Sc400 No Power at Full Throttle
- Smoking twins and.....smoking twins?
- 98+ ECU replacement / programming?
- Fresh 1jz Swap just finished No Key Start
- Exhaust help
- More damn issuses!
- More TTC questions
- Spark Detonation in SC300 question
- open/closed loop, tps, safc, blehhh?
- 2JZGTE Intake port?
- Advice / ideas using lauch control and posting my boosted 400 timing map.
- Sc400 is running rich still with SAFC
- Gas needle problem
- What can I do to gain NA Power?
- Are my mods safe for my 1jz twins?
- aluminum or copper crush washer ps
- 1jzgte No Boost
- Auto to Manual guys got a question
- Fuel Pump Issues, Don't know what to do next
- pulling code question
- Good Throaty Muffler Options
- Obx twin turbo kit
- Lend a helping hand please.
- water pump coolant leak
- Boost surging on and off??
- 98+ 5speed swap BACKUP LIGHTS?
- need to know if a 89 supra lsd will go in to a 93 sc300
- Just scored these 18's for $150.00
- Thinking about 1UZ Build. Questions
- What is the weak link in sc 400 trans?
- JDM 2JZ-GTE A/F at boost levels greater than 14psi
- SC400 Transmission wont hold much fluid
- I finally found a mustang that i love.
- Tribute To The 2JZ-GTE
- finally working on my own car
- I Need Info - swapping 1jz from 91 rhd supra into a 92 lhd sc400
- Loosing oil (2jzge)
- Wiring a 1jz Aristo to sc300 Wiring harness
- NA-T FFIM, 1jz iacv?
- Broke my rear! LOL.
- Getting vehicle speed reading to an aftermarket ECU info...
- aluminum radiator for 1.5jz
- power steering
- need help w/ driftmotion aeromotive AFPR kit
- W58 Transmission noise!!
- Help sc400 1992
- my sc400 hydraulics fan went bad help??????
- Where to hook up auto meter boost gauge?
- radiator
- RPM Help 98+ cluster w pics
- Can I run an aristo ecu on my 1jz soarer swap?
- parts interchange
- Power gains without turbo?
- Anybody running the megan motor and trans mount set?
- Battery Light. Altenator?
- Top 2 bellhousing bolt access?
- manual engine harness on an auto
- need help about harness
- 2jz rods newbie question
- 2jz egr system difference
- Long cranks on cold startup, bad FPR?
- Magnaflow 14829 vs 14828
- Driftmotion waste gates
- silicone radiator hose for 1UZ?
- 1jz Swap *Battery Keeps Dying
- SC400 torque converter.......
- meganVs. Magnaflow
- Anybody ever rebuild there rack and pinion?
- 2 Step on stock twins?
- 1JZ-GTE Non VVTI lately?
- SC300 idling high when cold
- t+t from the mkiv supra on my 92sc300 2jz?
- new exhuast concern.. is my new setup safe for my engine?
- Camshaft regrings options
- Ok sc400 needs more power asap!!
- Oil filter sandwich adapters/oil cooler adapters??
- Usdm and jdm ecu plugs for 2jzgte
- Need help first sc300 please!!!!!
- 3.5" Dual Exhaust Pictures???
- Twin fuel pump questions
- What plug is this for?
- Need Help Temp Gauge, Tach
- Full Throttle Performance Chip
- sc400question
- GenIII 6.0/t-56 swap thread
- Ultimate Spool and Response ???
- Are the 1JZ valve adjustment specs the same as the 2JZGTE's?
- New Clutch Slippage?!?!?!?!
- SC400 spitting, sputtering, engine shaking, no power
- cleaned IACV- now cranks but won't start
- Unrecircing stock BOV 1j
- SC300/400 1J/2J swap questions.
- 2jzgte vvti / To TTC or not?
- Aristo exhaust bolt up?
