- RX300 AWD Transmission symptoms
- Newbie question
- Driver window issue
- Amp Wire Diagram
- Ceramic brake pads
- RX300 Engine/Trans problems: Widespread or not?
- Help! Did I strip the oil filter screw on the engine????
- 2001 rx300 antenna
- rear hatch lift shocks supplier
- PCV/CCV problems...
- Good Code Reader?
- Door Lock & Driver Door Mirror Fault
- LOC install help
- Just bought a 2001 RX300, i have a question about the transmission
- Need New Struts?
- Need advice/info (Not using car for approx 45 days.)
- Installing Powered Subwoofer
- Transmission is Dead! I'm in a bit of a Pickle
- About to renovate my suspension - questions
- 2000 RX300 w/ding-ding sound and brake light on dash flashing
- Kool-vue side mirror ?
- Odd headlight question, stock HID install?
- Lexus RX 300 won't start (see video )
- Buyer Beware
- Intermittent Check Engine Light
- Maximum RX 300 AWd speed without the speed limter?
- rx300 with erratic shifting between gears. please help
- Z-max
- I cleaned my headlights with ATF - Automatic Transmission Fluid - It works!!!
- Clear on oil stick
- Good place to buy replacement Nav DVD unit?
- Brake Caliper Rubber Boot Replacement?
- Heat shield suggestions?
- passenger windshield wiper stoped working
- Brake Pads
- 5w-20??
- How to replace HID headlight bulb?
- Owners Manual
- Removing Parking Brake Cable
- if you have a second, please read here.
- First Post: Engine Cranks; Won't Fire.
- switching to synthetic ATF
- Valvoline Full Synthetic Racing oil VR
- ****EMERGENCY**** key internals
- Gas mileage computer information vs actual mileage
- E-3 Plugs
- pcv valve
- Cost of replacing Door Locks and Keys of 02 RX 300
- Cheap OBDII reader @ Costco
- What do you keep YOUR tire pressure at?
- Joined the RX300 World Today
- Power lock motor
- 1999 RX 300 ignition key is stuck
- Motor louder than usual!
- Cracked exhaust manifold.
- 99 Lexus RX300 maintenance suggestion need
- 02 Rx300 Rear Brakes Binding! Please Help!
- Need a new front and back bumper, Need help on Body parts
- DIY 1999 RX300 Exhaust without Lift?
- Code P0171 at 120K miles?
- DIY Catalytic Converter P1305-P1325
- What size tires on 18x8 and 18x8.5 5x.114
- Delayed shifts when cold.
- RX300 Silversport
- Interchanging rims with other lexus models
- What would be a good price to pay for a RX300?
- Will frequent oil changes prevent sludge/gelling?
- Caliper Maintainance
- USA SPEC PA15TOY (For my 03 rx)
- Multiple P1305 -P1315
- Any Preventive Maintenance For Air Conditioner?
- Lots of clues. Advice needed about rear end noise...
- muffler question
- low rpm when starts.
- 01 RX300 Door Removal
- Got light-brown coating on top of your headlight lenses?
- 2001 RX300, 18MPH, qualifies for "Cash For Clunkers" $4500 credit...
- Transmission Fluid(Sorry)
- TB Life - When all else fails, read the directions!
- Broken Wheel Lock
- CEL light is on
- Stalling w/ the AC on
- Rough start
- Steering Wheel Shimmy
- O2 sensor causing rough idle?
- Obvious oil sludge issue, claim denied
- Instrument panel, Hole cover
- Sub install PLZ help
- Auto-Rx
- Engine torque specs
- check this out!!
- Dead driver door power window fixed
- are there LED bulbs that's as bright as stock brake light bulbs?
- Duramax Gold Ceramic brake pads
- EDVANB in SC
- Start Up Squeak
- DIY: Engine removal and install????
- Need a double din dash kit--2000
- doesn't idle
- buying a 99 rx300 - some issues
- Does ES300 engine fit RX???
- Alternator Problem?? Please Help
- LED lights for high beam/daytime running
- HVAC Temprature control not working
- 2001 AWD trans on e-bay
- Honey like fluid in the intake
- Car doesn't move and then jerks when I press on the gas after braking
- clunking sound while driving in straight line
- Rims question.
- P1725 code- what is it?
- Dirty Headlight Housing...how to clean or fix
- Autotrans blues RX300 1999
- Alignment needed after strut replacement?
- 01 rx300 died driving help
- from bob is the oil guy.
- in 110+ degree weather, should I use a heavier oil than the usual Mobil 1 10W-30?
- Error Message 2
- driverside window wont roll up.
- Replacing Front Brakes
- Antenna replcement under CPO?
- 2001 RX300 Window Sticks
- 02 sensor diagram 99rx300
- dealer refused to sell me '08 navigation DVD because it won't work in '01 RX300?
- code throw 2009
- Auto door lock in D Position?
- Is it the Security System???
- Intermittent problem with passenger window
- Timing Belt DIY
- $2,400 for just fixing oil leaking?
- Broken hatch strut bolt
- 2001 OEM Navigation Kit
- how does the drivers side 4 button window switch actually work?
- good reading material
- Sludge in the intake
- Getting Spoiler Installed in Tampa, Fl
- 1mzfe engine components the same for es3 as ours?
- No 4th Gear !@$#
- Armrest replacement?
- Sound System Help!!!
- Possible transmission problem
- 2002 RX 300 wouldnt start this morning....
- need a little help
- '99 RX300 Consumed Oil
- Weird CHECK ENGINE light on 2000 RX300
- catalytic converter code popped up...now what...
- what does rx stand for?
- My RX acting a little...........
- HAPPY 4th of JULY!!
- "Bulb out" Indicator is on
- Rx300 a/c problems
- Radio back-lights turns off??? what gives?
- Engine codes
- Sagging driver's side sun visor
- FS 99 RX300 Spoiler Tan/Gold $50 + sh
- Excess oil useage freeway only!?
- Tail Lights
- changing the coolant soon
- help ... sell it or keep it?????
- How to remove trims with windows??
- Looking to buy first gen but had a few questions
- Just Got My First Car!!!
- A/C solar sensor circuit code 21
- engine knocking.
- Code P1155 - I need help please
- Metal Strainer
- RX300 2003: Replace Driver's Side Window Seal
- tinting windows on that goldish factory rx glass?
- P0765 Shift Solenoid "D" Malfunction
- Video of RX300 engine with Compressor/Supercharger
- Air Fuel Sensor
- Connect Iphone to Audio
- RX300 Engine Swap
- Strange clicking noise coming from somewhere below gear shifter?????????
- a/c vent problem
- Clock pinned at 1:00 AM
- replacing amplifier
- Yes you make a short blade key from a long blade blank
- in-line amplifier
- new amp in 99 rx300
- et
- Engine Air Filter and Oil Filter
- Squeaky steering wheel
- Making a long blade key into a short blade key
- Test drove a 2004 last evening
- Buying another RX, how to tell if it's got Nakamichi?
- 20's on an 02 rx300?
- where to find cupholder button?
- Replacement for Shocks...KYB?
- what model year did Toyota go from belt to chain?
- My speedometer is pinned at 6:00. What gives?
- Engine start button
- Newbie Transmission question
- CEL 0402 Catalytic
- Can the faceplate be removed?
- Struggle between 30 and 50 mph
- Cel p1135 & p1130
- Mileage VS. Age??
- Dual exhaust installed today
- '03 RX300 brake rotor question
- Please Help me Fish my power wire from the hood
- Need help on brakes
- Pics of my 2002 Lexus RX300
- Black box under the chasis rear driver side !
- fwd offroading?
- Replaced radio faceplate -- radio doesn't work anymore!
- Replace Leather Shift Knob RX300
- does anyone think im retarded for this?
- Radiator Replacement
- 1oz of Sea Foam
- Strange problem
- Considering a 2001 Rx...how much is too much?
- Air conditioning
- low speed shimmy
- What is "best" year of rx 300? awd or 2wd?
- VSC Trac Off Check Engine light on?
- Lost a/c after driving thru water??
- 2003 RX 300 timing belt question
- avg MPG 14.0 city, anyone thought about adding a bigger gas tank?
- Brake pad wear question
- 2000 RX300 rattling noise
- Electric Conversion Kit
- 2002 trade in value
- Refrigerant Leak
- brakes make a clicking noise
- Help! Transmission Failure symptoms
- New to lexus: Headlight housing?
- Sending out an ECM 89661-48082 for repair
- Searching for SoCal Mechanic
- New tires
- 2002 RX300 130K Maintenance
- Owner's Manual
- Two questions here
- A/C refill and service
- Oil Usage Issue
- check engine light codes
- Timing belt pulley.............
- Okay,here is one for you guy`s
- Secret weapon r intake gain hp ?
- TTE AND EIBACH LOWERING SPRING (Eibach Pro-Kit 8269-540)
- Flashing CEL P0303
- Transmission - drain and fill or strainer replacement first?
- Can you paint stainless steel?
- getting a 99 rx300 with 183k
- Hesitation on Acceleration
- Anyone try Castrol Edge Yet??
- Front Brake pads - remaining 8.5mm
- How to Disable ABS on 2000 RX300
- ever bend your power antenna driving too fast?
- car will start but shut off right away...HELP
- 99 rx300 led taillights
