Sub install PLZ help
Old Jul 29, 2009 | 05:13 PM
biggywilly's Avatar
biggywilly
Default Sub install PLZ help
Hello everyone. I just got my 2000 RX300 on saturday. I am a music NUT!! and my pervious car i had a system in it. I have all the stuff needed for a basic install Rockford Fosgate amp kit, Amp. 10in sub- for now my 12's need a new box. But can some one tell me what i need to do.
Thanks.
you can call me on my cell to walk me threw it. or text. 813 523 3025 thx names will.
Old Jul 30, 2009 | 08:56 AM
biggywilly's Avatar
biggywilly
Bump. Plz help
Old Jul 30, 2009 | 09:59 AM
salimshah's Avatar
salimshah
25 Year Member
What help are you looking for.
The factory sub is under the front passenger seat.
Salim
Old Jul 30, 2009 | 10:23 AM
biggywilly's Avatar
biggywilly
Salim
No i already found everyting the sub. and im pretty sure i know where the power for the back is that poeple plug into. I just need help wireing it up.
Old Jul 30, 2009 | 10:26 AM
robertrios's Avatar
robertrios
Yes the stock sub is under your front passanger seat which is where you tap the speaker wire to run back to a high low converter. I was initially going to DIY my sub install but I called my local shop where I also had work on my IS250 done and charged me about 130 for install, amp wiring kit, and a high low converter. Depending on where you are it might be a little more or less but definately not more then 200 bucks. It will save you alot of time and headache as well as the fact that it will look great.
If I were you I would just call around and get some pricing done. Some shops will even let you bring in your own hi/low converter and wiring kit which would save you alot of cash. The install labor itself at my shop was only 60 plus tax so if I hadnt just bought their wires and converter then it would have been an even better deal.
It really just depends on your budget. What are are you in?
Old Jul 30, 2009 | 10:29 AM
robertrios's Avatar
robertrios
I am assuming your talking about the power outlet in the rear hatch area, I wouldnt tap into that if your amp is high wattage...maybe a powered sub like a kenwood or basslink would be okay with that. Every install ive seen for a decent amp in this or any car has been powered straight to the battery to prevent any electrical issues/fires. You can easily ground back there though...lots of good spots.
Old Jul 30, 2009 | 10:36 AM
biggywilly's Avatar
biggywilly
Well im trying to aviod paying some one. Like i have everything to do but i still need to get a High low converter and i have no clue how to wire it. I got my 10in Rockford sub. 600 watt Rockford amp. And Rockford amp kit. And its in a 2000 RX300
Old Jul 30, 2009 | 10:38 AM
biggywilly's Avatar
biggywilly
yea i mean the amp behind the rear seats to get my sound. like i can do everything i just need help wireing into that amp so i can get the signal.
Old Jul 30, 2009 | 12:39 PM
robertrios's Avatar
robertrios
dont tap it from there tap it from the stock woofer under the front passanger your talking about the amp under the back passanger seat. I have heard subs sound better off the front passanger and thats also how they did it at my shop. Try searching on here for someone that did the install, your going to have to pass through the fire wall to get the power cable to the battery and then tap into the radio for the remote power cord. Its pretty labor intensive especially if you want all the wires hidden in that car.
Old Jul 30, 2009 | 12:55 PM
biggywilly's Avatar
biggywilly
Yea thats what i was thinking too. I got to that sub yesterday and i noticed its a 4 wire plug. So can u tell me which wires am i going to be using and what do i all need besides amp kit.
Old Jul 30, 2009 | 01:07 PM
robertrios's Avatar
robertrios
im not really sure i might have a site with it when I get home, someone that has alot of experience with OEM systems would know. Try member lexusaudio he knows alot.
vboi4life
Oct 27, 2012 05:41 PM
vultureskn
Jan 12, 2011 11:07 AM
Patfitz911
Aug 24, 2009 04:43 PM
beez43
Feb 2, 2005 05:13 PM
Phoenix88
Jan 27, 2003 05:12 PM
