- Help! Shift stuck between gears. Engine won't turn on.
- ABS Light
- Battery Dead?
- Tail light problem
- Replace master key / master key programming
- 05 rx330 headlights!
- P0430 Code
- Flashing AFS light fix
- Remove bumper on 2004 RX330
- Mysterious Parasitic Draw on 2007 RX350
- Radiator/Condenser fans
- Rear door issues - 2005 RX330
- 2005 car occasionally won't start. Dash lights up though and no noise
- Steering boot torn/leak
- Shopping for used RX350
- Coolant reservoir empty
- Scary power loss at highway speed
- 2004 rx330 line from thermostat housing
- RX Tranny Problems?
- Brake pad hardware question...
- Disable HVAC Air Conditioning Servo
- 13 years Later
- Rear driveshaft seals
- VSC and Check engine light. help
- 2004 RX 330 Key Lock Won't Lock
- An odd automatic window question
- Decent OE replacment aftermarket lights
- 2007 RX400H Liftgate mechanism malfunctions
- 2007 RX 400H Driver airbag light flashing
- 2007 RX400H engine codes PO101/PO441
- Battery sizes besides stock group 24F that will fit in 2nd Gen RX330 RX350
- HID headlamp assembly has moisture inside
- iPod Interface for rx350
- i am totally stumped
- RX 330 2004 delay in the morning
- Codes on 2005 rx 330 117k miles
- 06' RX 350 4WD air suspension conversion
- 05 - Driver's door lock switch works only when key is on
- plastic welding
- Fluid leak!!
- Swollen Lug Nuts
- Intermittent P0420 and P0430 -- 2005 RX330
- 2006 RX400h Totaled or can be saved?
- PCV Valve
- Need U joint that is connected to propeller shaft
- Memory seat issues
- shaking on braking
- Rear axle / differential carrier removal
- MYSTERTY w/pic: RX330 AWD Rear Strut Replacement Retaining clip fell from suspension
- Replace spark plug wires together with the plugs?
- Cracked radiator!
- P0300 error code
- Humming above 20mph
- backup camera stopped working
- black colored fluid
- Dash Cam Tap in Overhead Console
- "Shift to P when starting" when car IS in park? (2006 RX 400h)
- Gän Chip Tuning
- Most difficult RX330 problem
- 2008 RX350 Fender Liner Pad Insulator !?
- 2008 RX350 Fuel Filter?
- Cabin Filters - versions
- 255/55/R18 all terrains do fit, no lift or shims
- Alignment?
- Just purchased 2008 Rx350 and there is a leak.
- 2004 RX330 brake light failure
- My 2004 RX vs the new RX450h
- timing chain seal cover
- RX330 Seat Heater Diagram Needed
- Recommended Maintenance Performed
- 2007 RX350 Red Fluid Leak
- 08 RX350 Lift gate issues
- Metal vvti line replacement under recall
- 2006 RX330 Transmission leak
- 2008 RX350 All Dash Lights Turn On
- Piston sensor
- Guide on replacing rear diff driver axle seal
- NGK Ruthenium HX plugs?!!
- Need advice/help for replacing timing chain on 08 350
- Just bought a 2007 RX350 an hour ago...
- 2008 Rx350 Transmission fluid check with dipstick ❓
- My cruise control “speeds up” a lot on downhills. Any solutions?
- I need new wheel bearings and could use some help...
- Climate control on floor vents?
- Suspension height
- RX350 cranks but doesn't start
- quick belt question
- I Upholstered My Dashboard for $40 + Labor?!
- Touch-up paint
- Camshaft position b
- tailgate lift supports. / struts
- ABS and VSC lights on codes C1223 C1243 U0121 U0123 U0124 U0126
- Who's a Lexus genius?!? Help please!
- brake bleeding - 2005 RX330
- antenna broken at base
- Day time running lights not working
- 2005 RX330 Tansmission cooler lines to Radiator
- Scan tool that can read ABS codes
- Dashboard Color 2007 RX350
- valve cover slight oil seepage from the rear cylinder
- Precise location of oil pressure switch sensor for 2004 RX330
- Power door lift works only w/ fob
- Low Beams Not Working - High Beams, DRLs, Fogs All Work
- Mouse nesting on cabin air filter
- Dealer recommendations - kind of scary
- I loved this car, now it’s just a source of irritation every time I get in it.
- 2008 RX350 DIY fix broken exhaust valve spring
- Ignition Coil Replacement RX330 Cylinder 4
- Front end/steering issues...HELP!
- Radio Won't Turn on When Hot
- Sunroof won’t close properly
- Rooftop Tent?
- when to replace struts/shocks/springs?
- One tail light and one side marker out
- Hood latch won’t release
- Can I install Ford rim and tires to my RX350?
- Rx330 Coolant valley plate leak?
- Radiator Leak HELP!
- RX 350 2007 horn not working
- Panoramic Moonroof
- battery draining while sitting
- RX general questions
- Rear emergency brake seized
- 2006 Lexus rx400h
- 2005 RX 330 bluetooth backup cam self installation tips?
- Alternator brush assy replacement on 2005 RX330
- Jerky
- How to program rx330 remote and transponder
- PLEASE HELLP! rx350 factory amplifier is going into safemode
- Correct radiator replacement for 2005 RX330
- Replacement key fob
- 09 Lexus RX350 Heat Shield
- Power stering leaking 2008 rx awd
- Rear lift works on dash button and fob, not on lift itself.
- Recirculating button creates noise
- Rear knocking noise...bearing? Hlp
- RX350 Struts
- 2009 rx350 rear knuckle arm bushing part #?
- Need recommondation for new tire
- Antenna plug in
- 2008 rx350 parking brake chime sound too low
- Lexus rx350 turned off while driving
- 2007 RX400h clunking steering wheel when centered
- Is your headlight beam pattern flat?
- New head unit loses sound after 3.5 minutes every time
- 2007-2009 owners..show me your diff. Help pls
- 2007 Rx400h Rear Parking Assist Module Location
- several question about rx400h
- new strut and strut mounts[rear]
- Importing RX350 to Spain from UK - flat beam headlight pattern?
- Creaking/clunking sound when accelerating from a stop
- 2008 RX400 No start after Alarm fiasco
- I have a 2005 Lexus RX 330 wont start
- 2009 rx...symptoms of bad rear control arm bushing?
- Car alarm opening windows and doors
- Brake line accident!
- Would this single DIN stereo fit?
- vacuum hose routing question
- Master Cylibder Replaced and bench bled no pedal
- I searched, peeling door trim issue
- New owner of a 2008 Lexus RX350, not a car guy. Could use some help
- Another knock sensor error question
- Just purchased 2008 Rx350.
- SONIC bushes and control arms
- Ongoing A/C Problem after compressor replacement
- sticky dash fix?
- 2004 RX 330 lovingly maintained, but still makes cracking sounds
- 5x115 20" 245/45/20 On An RX330?
- Best Rims and Tires Sizes for RX330
- Rx 330 help needed, please..
- 2007 rx 350 driver side headlight assembly & fender install
- CVT transmission and differential fluid change
- Is this 2008 RX 350 a good buy?
- Japan/Canada brakes
- ABS VSC and blower speed craziness
- Doors not locking
- What would cause shaking on acceleration?
- Suspension height
- 2004 Lexus RX330 Stranded Yesterday
- Service book and service intervals
- fuel system cleaning
- Windows not working at all - where is the fuse?
- Loving my 2005 RX (6 months in)
- 2008 Rx 350 navigation display installation
- Gas mileage
- Removing Wood Trim
- Steering wheel vibration, not wheel balance
- Wheel bearing
- Rear Strut replacement
- 5 things that will break on the RX (some happened to me)
- RX350 Oil Canister assembly
- RX350 infotainment screen black
- RX 400 h: How do I turn exterior lights off?
- Blinking Security Light
- RX350 Grille bolts stuck...
- Where to buy coil springs??
- RX330 2004 - Clunking and scraping noise from rear passenger side
- Spare tire question?
- Dust dust dust
- Front strut removal..remove axle??
- Ticking noise with fluctuating vacuum
- RX350 rack and pinion
- Is there a buffer on top of strut?
- 2004 RX330 P0333 code knock sensor bank 2
- Oily substance on passenger floor mat
- RX350 front suspension cost estimates?
- Power steering pressure hose replacement
- plastic welding
- Catalytic Converter
- Which radiator for 04 RX330 2WD?
- Possible rear strut change? If so which quick struts are good?
- Window button not working
- Fender liner replace
- B1400 code need help with description of code
- Residual autonomy
- 2005 RX 330 VSC Trac Off Reset
- ECU reprograming with Techstream
- 120K Service
- My RX died
- Headlight assemblies
- Bad sway bars? Already?
- Can’t Locate part number for engine area splash guard!! Grrrrr!
- Engine Overheats at Idle; Fans are Spinning
- Hid lights and high beams
- Steering Rack & Pinion Bushing Kit Replacement for 2004 Lexus RX 300
- Steering Rack Bushings
- Power windows stay on (live) with car off?
- Squeaking steering wheel
- Possible rear struts knocking.. change part or quick struts?
- Error messages 2008 Rx400h
- 2005 rx300 sat nav upgrade
- Need help with rx400h
- Help ! 2009 RX 350 question
- Key Fob Ticking
- RX 400h interior project (Carpet dye + new seats)
- RX330 240,000 Mile Maintenance
- New Strut Assembly [4]
- wheels finished at last
- You're Not Gonna Believe This
- Front strut bar tower on a 2007 rx 350
- Strut Assembly replace
- Factory Sirius/XM anttenna wiring harness
- Leak under driver's foot well.
- Update on clunk..
- Red Calipers
- Amplifier
- After Market Stereo in an 08 RX
- New rear strut ass'y
- air pump for tires
