B1400 code need help with description of code
Old Jul 2, 2020 | 07:24 AM
Kahrbean's Avatar
Kahrbean
Default B1400 code need help with description of code
Good day all. I am a new owner of a previously experienced RX330. I am reading an OBD code B1400 and I am unable to nail down a cause of this code. The usual internet search has offered up such things as a broken MAS air sensor, and Transmission Engaged At High Throttle Angle. I searched this forum for any data and came up empty. The vehicle has 96,059 miles, runs perfect, starts without any real issues, and I am experiencing about 22 MPG driving back and forth to work on surface roads with minimal stops and starts. Thank you in advance for insight you can offer.
Old Jul 2, 2020 | 09:59 PM
DennisMik's Avatar
DennisMik
I did a google search on lexus B1400 and got this result - ( http://b1400.enginefaultcode.com/lexus-rx )
Here are some excerpts:
While fuel economy was increased, acceleration was seriously compromised, and the loss of engine vacuum led to a dangerous loss of braking assist when the B1400 code system was in four-cylinder mode.
it would probably be worthwhile to carefully inspect the wire harness near the intake manifold bracket. This is done most easily from below the car in the area near the oil filter.
Old Jul 3, 2020 | 01:16 PM
Kahrbean's Avatar
Kahrbean
Thanks DennisMik for that link.
Calin72
Hybrid Technology
Mar 29, 2019 11:50 AM
SCORP69
IS F (2008-2014)
Mar 7, 2019 12:04 PM
diverchris
May 1, 2014 01:20 PM
imDementeD
Mar 8, 2011 01:03 PM
