Camshaft position b
Old Sep 22, 2020 | 08:11 AM
Willsnyd2's Avatar
Willsnyd2
Default Camshaft position b
Does anyone know where the camshaft position B is located on my 2008 Lexus rx350
Old Sep 22, 2020 | 12:42 PM
Mesquite77's Avatar
Mesquite77
That would be the exhaust camshaft, bank 1 I think. Lots of info if you search for:
"P0014 OBD-II Trouble Code: Camshaft Position B - Timing Over-Advanced or System Performance (Bank 1)"
Old Sep 22, 2020 | 01:27 PM
DennisMik's Avatar
DennisMik
Also P0015 OBD-II Trouble Code: Camshaft Position B - Timing Over-Retarded or System Performance (Bank 1)
Bank 1 is the side of the engine next to the firewall. These 2 codes refer to the intake valve camshaft, not exhaust.
The Engine Control Module (ECM) controls the Oil Control Valve (OCV) to regulate the intake camshaft angle. As a result of the angle change, the engine timing is advance or retard. Optimizing engine timing will help the engine improve torque and fuel economy, and the exhaust emissions decrease under overall driving conditions. The Variable Valve Timing (VVT) system includes the Oil Control Valve (OCV) and VVT controller. The ECM detects the actual intake valve timing using signals from the camshaft and crankshaft position sensors, and performs feedback control.
Old Sep 22, 2020 | 03:00 PM
Willsnyd2's Avatar
Willsnyd2
I believe it was p0016 was the code it was throwing. Engine now feels sluggish and struggles to shift into gear sometimes. Do you know how easy this would be to change myself? Or would you recommend a mechanic to fix it?
Old Sep 22, 2020 | 05:22 PM
DennisMik's Avatar
DennisMik
The description for P0017 is
P0016 LEXUS Description - The Engine Control Module (ECM) controls the Oil Control Valve (OCV) to regulate the intake camshaft angle. As a result of the angle change, the engine timing is advance or retard. Optimizing engine timing will help the engine improve torque and fuel economy, and the exhaust emissions decrease under overall driving conditions. The Variable Valve Timing (VVT) system includes the Oil Control Valve (OCV) and VVT controller. The ECM detects the actual intake valve timing using signals from the camshaft and crankshaft position sensors, and performs feedback control.
The vvti is on the passenger side of the engine near the top. I would think it would be fairly easy to change.
BruceUtter
Jul 1, 2018 08:54 PM
lottaloot
Lexus Vehicles Classifieds
Apr 26, 2013 01:39 PM
408IS350
65
Sep 1, 2008 10:00 PM
MPLexus301
Jul 6, 2007 09:51 AM
