HID headlamp assembly has moisture inside
Old Oct 26, 2020 | 09:03 AM
pacdude's Avatar
pacdude
Default HID headlamp assembly has moisture inside
My grandparents have a 2009 RX350 with HID headlamps, and the right side one has moisture inside. A new headlamp assembly around $2000, which they do not want to pay. Is it possible to take these headlamp assemblies apart and reseal them to prevent moisture from getting in?
Old Oct 26, 2020 | 09:34 AM
RXGS's Avatar
RXGS
Yes, but before you do take out the access panel for the bulb replacement, place a hairdryer in there, and let it air/dry out best you can.
Otherwise you have to take it out of the car, place in the over to take off the lense, and put it all Back together.
people have also put tiny silica packets In the assemblies to try to dry out them out
In my past 2 GSs, the moisture seemed to be getting in from the plastic cover on top of the headlight, that lets you see the headlight level. On those cars, I was able to tighten down the cover with Phillips screwdriver, but I don’t know if it’s the same for the RX or if it’s even the same cause. I remember there was a TSB/warranty on moisture in the headlights, but I would be shocked if the car was still covered. No harm in checking though
Old Oct 26, 2020 | 11:24 AM
iMSQ's Avatar
iMSQ
1. It doesn't cost so much (you need the "body" only, no bulbs and discharges)
example: https://www.lexuspartsnow.com/parts/...130-48680.html
2. Check the headlamp body for
  • cracks or damages
  • bulbs are installed correctly
  • all covers are closed as it should be
  • ventilation is clean and without damages
Old Oct 26, 2020 | 06:47 PM
Margate330's Avatar
Margate330
I got new aftermarket replacement HID headlights a couple years ago on ebay for $90 each.
Mine were dingy and old looking so I wanted new anyway.
See my profile pic if you want to see.
Old Oct 26, 2020 | 08:20 PM
iMSQ's Avatar
iMSQ
IMHO. It's better to restore the OEM (https://www.clublexus.com/forums/rx-...eadlights.html) than buy "no-name" headlights. Safety first!
Old Oct 26, 2020 | 09:10 PM
98sscamaro's Avatar
98sscamaro
Has the car ever been in an accident or damaged in that area? If so the housing could be cracked. Also, check that all the vents on the light are not plugged and the cover on the back is secure.
Old Oct 28, 2020 | 07:23 AM
matts6887's Avatar
matts6887
did you happen to see if there were the ones like mine which are hid plus afs?
Old Oct 28, 2020 | 08:43 AM
Margate330's Avatar
Margate330
My original had HID & AFS so I just ordered the HID version and didn't plug in the AFS plug if I remember correctly.
There are some HIDS w/ AFS used on ebay used oem original.
Old Oct 28, 2020 | 10:41 AM
matts6887's Avatar
matts6887
yea the problem with the hid plus afs ones is they are ungodly expensive $$$$$$$
Old Oct 29, 2020 | 06:22 PM
TimB52's Avatar
TimB52
Seems there's an entire thread about this issue on the next page!
https://www.clublexus.com/forums/rx-...post-19-a.html
dunk50
GX - 1st Gen (2003-2009)
Oct 29, 2020 07:55 AM
Sin1UZFE
Apr 17, 2020 06:41 PM
lextout
Oct 16, 2016 04:00 PM
LarsLexus
Apr 18, 2011 06:46 PM
gsCrazy
Aug 17, 2009 01:18 PM
