Tail light problem
Old Nov 17, 2020 | 07:27 AM
drivernuts's Avatar
drivernuts
Default Tail light problem
On my 2007 RX350 there is a small icon on the tach display that indicates something is going on with my tail lights. I checked out this issue and could find nothing wrong with all the rear lights. The icon only shows up when I turn on the lights. Does the icon need to be cleared somehow or do I have some other problem that needs to be addressed? Thanks for any thoughts.
Old Nov 17, 2020 | 05:46 PM
Felix's Avatar
Felix
Possibly a bulb is out. I ended up just replacing all the rear bulbs as one was out....
Old May 24, 2021 | 08:47 PM
rusn007's Avatar
rusn007
Which light bulbs did you use to replace your rear bulbs? One of my rear light fixtures is barely working and I'm looking to replace the bulbs.
Thanks
Old May 25, 2021 | 06:37 PM
RadiantX45's Avatar
RadiantX45
If it’s just a tail light it’ll tell you what to use in the manual. If it’s the actual LED BRAKE lights causing the notification then you will not be able to replace them individually. The full light assembly will have to be replaced unfortunately - so most just keep what they got.
My tail lights even in my 3rd gen go out all the time. I just hit the assembly with my fist while walking by and they come back on. They obviously need to be replaced but this works for now. Luckily my LEDs are still holding strong!
Old May 27, 2021 | 09:04 AM
mandyfig's Avatar
mandyfig
If it is random, then one of your tail lights is loose. Unfortunately to get it corrected, you will have to tear down the latch to access the lights. I have an on and off situation as well. I try the banging method but I know one of these days I just have to get in there. I replaced mine with LEDs and they wiggle and get disconnected.
Old May 16, 2025 | 10:48 AM
panocean's Avatar
panocean
i also have my lexus rx 350 2008 both tail lights arent turning on bulbs are good any solution?
Old May 19, 2025 | 11:21 AM
Felix's Avatar
Felix
After tapping one of the taillight housings a couple light went on, after a couple ttimes of doing this, I just bought a commerial pack of #168 bulbs, which I reeplaced all the bulbs, as well as a couple #921 bulbs for the reverse bulbs. No issues for yrs, I also replaced the foglight #9005 bulbs for LED ones too..........
Nckerk
Nov 17, 2020 07:23 AM
aaloo
Sep 21, 2011 12:29 AM
jdmshawn
Apr 9, 2011 07:58 AM
lxus4xms
Jan 15, 2009 06:05 AM
