Wheel bearing
Old Jul 18, 2020 | 12:36 PM
shikbas's Avatar
shikbas
Default Wheel bearing
Hi guys
i have 2004 rx330 ,all wheel drive ,90k miles
started to hear droning noise at speed 30-40 miles then getting louder,put trany in neutral,same noise so I suspected a shot bearing,after lifting the car I have the passenger rear tire with some play when moving it side to side but not any other one
Is that the bad one?
thank you
Old Jul 18, 2020 | 02:09 PM
Lexuswiz's Avatar
Lexuswiz
My money is on that too, usually play is a sign of a failing bearing. BUT, I would replace in pairs, when one fails, the other will most likely be right behind it.
Old Jul 19, 2020 | 03:21 PM
Felix's Avatar
Felix
Yeah, I'd do that a on the front being pressed in to the spindle.....Rears are easier to do.....I'd just replace the one thats bad for the rear.
Old Jul 24, 2020 | 04:07 PM
roadbike56's Avatar
roadbike56
FYI, I had a left front wheel bearing go and only replaced the one, failed wheel bearing. That was 30K miles ago. No problems with the OEM right side. I'd only replace the wheel bearing that failed. YMMV.
Old Jul 25, 2020 | 08:57 AM
cdnewton's Avatar
cdnewton
The right rear failed on our AWD RX330. I asked the tech about replacing both and they recommended only replacing the bad one. That was at 199k and the vehicle is coming up on 260k. Based upon my experience, I would only replace the bad one.
Old Jul 25, 2020 | 09:02 PM
iMSQ's Avatar
iMSQ
Originally Posted by cdnewton
... and they recommended only replacing the bad one. ...
That's true. Left and right sides are not correlated.
PS: Only tires, brakes and struts have to be replaced "by pair".
Old Aug 13, 2020 | 08:37 AM
shikbas's Avatar
shikbas
Thank you all
The bearing was replaced,car is quiet again
Old Aug 14, 2020 | 03:13 AM
Mc88Flyy's Avatar
Mc88Flyy
I just bought an 07 and around 40+mph I'll get the mud tires on hwy sound. Doesn't get louder with speed or turning though. Sounds like its the right side, so I guess I'll jack it up and shake the wheel and see if there's play. The tires have 10k on them, albeit their an off brand.
GSdre
May 9, 2020 04:53 AM
Bocatrip
Mar 2, 2016 09:56 PM
Behemoth7
Dec 2, 2014 10:34 PM
donmck1950
Nov 16, 2014 08:32 PM
sbgs400
GS - 1st Gen (1993-1997)
Nov 24, 2002 01:14 AM
