Ignition Coil Replacement RX330 Cylinder 4
Old Sep 10, 2020 | 02:00 PM
mandyfig's Avatar
mandyfig
Default Ignition Coil Replacement RX330 Cylinder 4
I recently had a P0304 CEL and rough idle, misfire. Fortunately it was Cylinder 4 (P0304 - 03 means misfire; 04 means Cylinder 4) which was located in the front bank. I had a P0305 (05 means a back located ignition coil) back in December and I had the back Ignition coils replaced by my trusted mechanic because you all know how hard or cumbersome it is to do the back cylinders. I requested that I be given the 2 good coils for eventual re-use. I can not find the other 2 coils which were still good, I forgot where I put them - I am getting old...(lol..and it will happen to you someday too!). I quit looking for it and purchased a Denso replacement from .mazon - $51, came in 2 days. What came is a direct replacement, cool. In fact I recognized it since my old company used to mold the plastic that housed the coils. This Stick Coil do not look like the original, looks different (the old ones are a bit semi-round and this new one is square-ish). I dropped it in and fired it up as normal.
Lesson learned: When you have spare components, take a pic of where you stash it, will save you a headache and some $.
Pics below...
Old Sep 10, 2020 | 06:20 PM
Felix's Avatar
Felix
Great idea, 'bout a quick pix of where you put somethings......
Old Sep 11, 2020 | 12:24 PM
mandyfig's Avatar
mandyfig
LOL, I am still scratching my head on how clever I was with the hiding of the 2 Ignition coils! On of these days they will show up. But the thing is because of this Covid thing I have cleaned up the garage and my storage top down. I did not come across them. Wait I have not checked my storage bin in the RX, the one in the bottom of the cargo.
Old Sep 11, 2020 | 01:25 PM
Mesquite77's Avatar
Mesquite77
BTW, the locking clip is broken off the wiring clip on #4 (they all break). Likely it won't budge since the seal makes a tight fit, but on mine, I just add a dab of silicon (gasket maker, shoe-goo etc.) to stop it vibrating loose. easy to peel silicon off if you need to remove it in future.
Old Sep 13, 2020 | 05:53 PM
mandyfig's Avatar
mandyfig
You noticed about the broken clip, good eye. And yes after many years and the temps they are exposed to, they get brittle. I was going to wrap it with high temp tape. Thanks for the reminder.
Old Sep 14, 2020 | 08:14 AM
matts6887's Avatar
matts6887
actually thats a good idea. Yea mine are probably brittle too from being exposed to the intense arizona heat. I just had carpal tunnel surgery on my left hand so i only have one free hand right now to check them. so when i get 2 free hands i will get out there and check them.
Dlogvine
Jul 16, 2019 03:16 PM
speedkar9
Dec 25, 2017 04:35 PM
yennit
Jan 20, 2013 11:23 AM
91supra
IS - 1st Gen (2001-2005)
Dec 17, 2008 10:54 AM
HearMyLX
Mar 21, 2006 01:45 PM
