Memory seat issues
Old Oct 16, 2020 | 07:14 PM
PofC's Avatar
PofC
Unhappy Memory seat issues
My memory seats stop working. I know is not because of the battery. The manual adjustments work fine just the memory buttons dont work. Anyone has any ideas or a diagram to share how to troubleshoot. I check the fuse and is fine and even took the door apart and check the connections inside and under the seat and everything seems fine. What gives?
Old Oct 17, 2020 | 10:00 AM
Trebbor's Avatar
Trebbor
Not sure what to do to check out the memory system, but I've attached a pdf of the manual on seats that has a lot of information which may help. Good luck. Bob
File Type: pdf
Old Oct 18, 2020 | 11:10 PM
Margate330's Avatar
Margate330
Does the memory botton located on the driver's door move the steering wheel and mirrors to their proper position or are they not working too?
If you don't have memory mirrors this test won't work.
Old Dec 17, 2020 | 02:29 PM
JonVal's Avatar
JonVal
I had this issue.
It is like the boot not working or the windows after dead battery.
1. Move the seat forward until you hear a beep.
2. Move the seat all the way back.
3. Move the seatback angle switch forward until you hear a beep
4. Move the seat back angle switch all the way reclined.
5. Set the memory now.
I did not hear any beeps but memory started working.
Old Dec 18, 2020 | 10:45 AM
Margate330's Avatar
Margate330
Originally Posted by JonVal
I had this issue.
This is good info.
Thank you for sharing your fix.
Motorola
Oct 13, 2022 01:45 PM
midwest2
Jul 19, 2021 04:13 AM
cm18cam
Apr 10, 2017 07:23 PM
jsambo
Jun 27, 2015 07:25 AM
Bj(CA)
Jun 30, 2011 02:11 PM
