Is your headlight beam pattern flat?
Old Aug 16, 2020 | 10:45 PM
dingobingo's Avatar
dingobingo
Default Is your headlight beam pattern flat?
Hi
I asked a question a few days ago and maybe it got bogged down with the details so I'll change the question.
1) Were all 2nd gen RXs sold with HID headlights?
2) What is the beam pattern (if you turn it on outside your garage or a wall for example), is it flat or is there a big rise on one side or the other? Photos would be awesome
Thanks all.
Old Aug 17, 2020 | 04:45 PM
Lexuswiz's Avatar
Lexuswiz
1. No, only premium or hybrid packages. But all HID equipped RX's came with AFS as far as I know.
2. Typical projector style cutoff (not to be confused with halogen reflector). Best I can describe it as is two stretched Z's next to each other, don't have any pics at the moment.
Old Aug 18, 2020 | 07:46 PM
iMSQ's Avatar
iMSQ
1) No, not ALL 2nd gen RXs have HID.
2) My left headlight wasn't leveled well when I made this photo.
Old Sep 7, 2020 | 12:24 AM
dingobingo's Avatar
dingobingo
Thank you both.
Is there a quick way to tell if a car has HIDs other than asking the owner to do above? I noted on UK autotrader the car descriptions do not include this information. Or any visual way to spot the difference looking at photos of the headlights?
Old Sep 7, 2020 | 06:56 AM
Lexuswiz's Avatar
Lexuswiz
If you look at the headlight, you will see an "eyeball" (glass lens) where the low beam is. Usually will only come on cars with 5 spoke 18" wheels, whether premium package or hybrid. If you see a 6 spoke 17" wheel, then it will (typically) have a reflector instead of the eyeball in the low beam area.
Here is mine with HID AFS:
Old Sep 7, 2020 | 08:07 AM
matts6887's Avatar
matts6887
I know mine too has afs and the hid's; but i dont have any pics of it at the moment.
Old Sep 7, 2020 | 08:19 AM
Felix's Avatar
Felix
Basically if it has AFS, then its hid equipped.......One quick way,there's a switch which you can turn off the afs...
Old Sep 7, 2020 | 12:51 PM
iMSQ's Avatar
iMSQ
What bulb did you place into High beam? Does it still work as DRL?
Old Sep 8, 2020 | 02:51 PM
Lexuswiz's Avatar
Lexuswiz
That pic you're seeing is an LED in the running light (not DRL), type 194. I do have LEDs in the high beams but they do not work with the DRL, I have permanently disabled DRLs on the BECU.
Old Sep 22, 2020 | 10:58 PM
dingobingo's Avatar
dingobingo
Thanks again, and I am guessing the switch on the dash or console would be labelled AFS?
Old Sep 23, 2020 | 09:45 AM
matts6887's Avatar
matts6887
yes; the switch is located near the "lower panel" just to the left or so about where your left leg for most people would be. it will say afs off on it. I know this cause my 07 350 has the hid afs lights.
Old Sep 23, 2020 | 10:43 PM
dingobingo's Avatar
dingobingo
Thanks. Time to go 350 shopping
dingobingo
Aug 14, 2020 10:04 PM
psaav
Dec 14, 2017 11:03 AM
BrightonB
Jan 6, 2013 07:47 AM
KPC
IS - 1st Gen (2001-2005)
Apr 2, 2007 09:33 AM
Jubane
RX - 1st Gen (1999-2003)
Nov 5, 2005 02:45 PM
