2007 RX400h clunking steering wheel when centered
Hello,
This is my first post, so greetings everyone.
Recently noticed an issue, which can be very well observed in the attached video (wmw format open with vlc media player)
When the steering wheel is moved left and right in the center, it makes a clunking, almost metallic noise. The noise is located behind the steering wheel. Noticed it when i was running over rail roads and gravel, so it can be observed only on low speed or when completely stopped.
Sounds like a wear rubber to me but the only solution i found so far is to replace the entire steering column.
Anyone else experienced this?
Regards,
Savin
Regards,
Savin
Hello,
Regards,
Savin
Regards,
Savin
I'm also having the same issue. Did you ever find a resolution?
GoHuskers
GX - 2nd Gen (2010-2023)
48
Feb 23, 2026 10:44 AM
rocketpope
Aug 31, 2018 08:53 PM
lexuschar
RX - 3rd Gen (2010-2015)
Dec 4, 2016 01:13 AM
B43088
Dec 21, 2011 04:38 PM
