Front strut removal..remove axle??
Old Jul 11, 2020 | 12:45 PM
fabchef's Avatar
fabchef
Default Front strut removal..remove axle??
Hi guys, i will probably change front struts. I was watching a video, where the axle nut was removed to make room for strut. Is it necessary to remove the nut? Is there enough room to do it with nut on?
Fab
Old Jul 11, 2020 | 01:19 PM
Mesquite77's Avatar
Mesquite77
I took both my (FWD) struts off, did not touch the axle or LCAs. I did undo the stabilizer link since I was dropping the sub-frame, not sure if that is even needed. I also hung the break calipers from a wire, and unscrewed the ABS sensor wires that are tied to strut.
Old Jul 11, 2020 | 01:26 PM
fabchef's Avatar
fabchef
Mesquitte. I have an awd model, but should be the same. I know you have to undo the links.
I don't think you need to undo calipers as they are more towards front of car, no?
Once you unbolted bottom bolts of strut, how did you actually get it out (bush strut inward and slide out)???
fab
Old Jul 11, 2020 | 03:34 PM
Mesquite77's Avatar
Mesquite77
Dang things almost fall out once top and bottom bolts off, don't recall any problem at all, and they were lighter than I expected. Just undo the bolts and go for it.
Old Jul 11, 2020 | 04:14 PM
fabchef's Avatar
fabchef
Mesquite, ok thanks. What year is your rx350?
Old Jul 13, 2020 | 12:34 PM
iMSQ's Avatar
iMSQ
https://www.clublexus.com/forums/rx-...l#post10476261
Jacob21
Suspension and Brakes
Dec 18, 2025 01:48 AM
speedkar9
Oct 12, 2018 06:13 PM
tritron
May 28, 2007 10:39 PM
gs4rocks
Nov 18, 2005 10:01 AM
