Error messages 2008 Rx400h
Old Jun 22, 2020 | 04:27 PM
Xfithobbs6's Avatar
Xfithobbs6
Default Error messages 2008 Rx400h
I was driving yesterday and these codes appeared out of nowhere. I stopped and checked the oil, fluids and gas cap; all fine. I continued driving another 6 hours without any loss of performance. I stopped by a garage this morning and they hook the code machine up to it and it didn't show any codes. Oil change was 6 weeks ago. I only use Shell Premium fuel. I noticed today that I had a message, check VSC system. I disconnected the negative battery terminal but it did not make lights go away. He
Old Jun 23, 2020 | 01:51 AM
Mesquite77's Avatar
Mesquite77
The VSC and ABS lights can be on because those functions get disabled when another problem prevents normal operation, so not sure what the "red" light is, but you will need to find the root cause first.
If the brake warning light comes on when you apply the brakes, or is on continuously, it means that hydraulic pressure has been lost in one side of the brake system or that the fluid level in the master cylinder is dangerously low (due to a leak somewhere in the brake system).
If it is an ABS problem, there are several posts on this forum about how to track down the sensor problems at the wheels.
And, another problem, using your phone to take pictures while doing 82 mph?
RUSmiling
May 29, 2018 05:55 PM
JuanM1
Oct 9, 2017 10:17 AM
RC1047
Feb 3, 2011 12:53 PM
mottand4
Jan 21, 2010 10:49 AM
