Bad sway bars? Already?
Old Jun 27, 2020 | 12:40 PM
fabchef's Avatar
fabchef
Default Bad sway bars? Already?
Hi guys, as i had mentioned before i've been trying to figure out this rear end clunking.
I was inspecting the rear sway bars that i had changed out, about 5 months ago. They installed aftermarket bars (mevo) and shortly after, one of them has snapped ) bolt that hold on, at bottom of bar). They replaced it under warranty, but looking at them now, the bar bolts are twisted to the extreme at the top and bottom of bar. They don't seem to sit straight. Can the bars be wearing out(ball/socket internally)?
Should i go with oem bars instead?
Any issues with aftermarket bars?
Thanks
fab
Old Jun 28, 2020 | 10:56 AM
Felix's Avatar
Felix
The aftermarket bar should have the same bends, length,ect. The brackets that bolt the bar to the frame/cradle should have the same length or you'll need to ablong the bolt holes. The endlinks should be the same length as the oem ones. btw, Why did you need to replace the sway bar for? Yea, possibly the bushings or the endlinks thou........
Old Jun 28, 2020 | 11:41 AM
fabchef's Avatar
fabchef
Hey, the actual sway bar seems to still be ok. It's just the sway bar links that I think i'll change. I'm curious though.. is the rear shocks go bad can the affect the actual sway bar at all?
i looked at the front oem links, and they sit perfectly (not twisted or bent at all) the rears are kinda twisted (long threaded bolt).
I'm just skeptical on the quality of these links. Unless the are the wrong links to begin with??
fab
Old Jun 28, 2020 | 07:53 PM
Lexuswiz's Avatar
Lexuswiz
Never had luck with any aftermarket links for the same reasons. I now go OEM only.
Old Jun 29, 2020 | 07:29 AM
Mevotech never lasts.....try a quality part instead
MilkMonstr
Suspension and Brakes
18
Sep 7, 2017 08:54 AM
m1k3yg
GS - 1st Gen (1993-1997)
Apr 29, 2012 09:43 PM
hurricane
15
Oct 30, 2008 06:58 PM
ByoungWoo
Oct 11, 2007 12:37 PM
prep2
Sep 20, 2005 06:52 PM
