Are these bad caps???
Old May 22, 2013 | 10:44 AM
Bender25's Avatar
Bender25
Default Are these bad caps???
Inspected ecu and found this, thoughts??????
Attached Thumbnails Are these bad caps???-20130522_103431.jpg   Are these bad caps???-20130522_103449.jpg   Are these bad caps???-20130522_103342.jpg   Are these bad caps???-20130522_103229.jpg   Are these bad caps???-20130522_103210.jpg
Old May 22, 2013 | 11:11 AM
GTE4Life's Avatar
GTE4Life
I'm not an expert but I think the connections don't look very healthy, they may still be functioning fine though. If they're bad it's not too hard to get some new capacitors and solder them in. Good luck
Old May 22, 2013 | 11:18 AM
mattjk's Avatar
mattjk
They are definitely bad. They don't have the relief cutouts on the top so instead of bulging on the top, the fluid is leaking out the bottom through the leads.
Old May 22, 2013 | 11:29 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
both look like they are leaking some of their di-electric material, if that's the case they are going bad.
Once it starts loosing the liquid the capacitance changes and things will get worse the more it leaks.
You can also see the surface traces leading away from them turning darker, but it still looks repairable.
I would remove caps and wipe it clean with the electrical parts cleaner, and re install new caps.
Old May 22, 2013 | 10:41 PM
Bender25's Avatar
Bender25
Well I don't know how to solder so I gotta find somebody to do it. Are the capacitors available at radioshack?
For ****s and giggles here's a pic of the same caps from this past September https://www.clublexus.com/forums/sc-...-look-bad.html
Old May 22, 2013 | 11:56 PM
mattjk's Avatar
mattjk
Im an electrical engineer, design circuit boards. Where in ca are you located? I can change them.
Old May 23, 2013 | 05:14 AM
Vrank's Avatar
Vrank
And if this guy isn't close, you could probably have a local computer place do it for pretty cheap car audio equipment repair shop, even a cell phone repair shop since they do a lotta board work replacing mic's and speakers, etc. You might be able to find the capacitors at like maybe a radio shack, frye's electronics, or possibly car audio repair shops. We have a place locally that rebuilds decks, amplifiers, etc. They usually have the caps I can't find locally between the other places I mentioned.
Old May 23, 2013 | 09:07 PM
Bender25's Avatar
Bender25
I'm in Santa maria, ca. Where are you located?
I'm gonna ask the people at my dealership tomorrow
LilMan23
Feb 14, 2011 10:01 PM
chwES300
Jan 9, 2010 11:41 PM
omarg
Apr 10, 2008 10:12 AM
z16
Wheels and Tires Classifieds
Nov 25, 2007 11:41 AM
uschardcor
Aug 23, 2006 10:45 PM
