Help!!! faulty MAF sensor not sure
hey im new to this forum, and ive had my sc400 for about6 months now, its been undergoing repairs and what not, but there is a problem which i believe is the mass air flow sensor. when its unplugged, my car runs fine, but once pluged in, the tach bounces all over the place and then the car shuts off. here is a video
please help! thanks guys
no im actually the only one with an sc, but there is a guy on the other side of my neighborhood who has an sc, not sure if its a 300 or 400... he removed the emblems. can i try a sc300 maf sensor on mine?
Search function is your friend! https://www.clublexus.com/forums/per...for-sc400.html
Seems to me it'd be the MAF, but can't be sure. CEL?
moved to maintenance section, please post in the proper sub forum.
could be maf or some say any of the sensor the ecu uses in closed loop. o2 sensors could even be suspect if they have never been changed in a very very long time.
read this thread.
https://www.clublexus.com/forums/per...n-92-94-a.html
read this thread.
First I'd double check that the MAF is properly seated. If it isn't properly seated in the hole and is even at a slight angle it can do that. My car had the same random loping idle. I run with the MAF unplugged for several months, and finally realized it was such a simple fix!
