clutch problem?
Old May 27, 2013 | 01:49 PM
TEAMxREX's Avatar
TEAMxREX
Default clutch problem?
i have a maunal (w58) trans in my car and the clutch catch point is high. There is no slippage and no grinds at all and last owner said he replaced it in 2010 and after he said there was a lot of material left. please help so i know if i have to replace the clutch.
thank you
Old May 27, 2013 | 01:55 PM
mattjk's Avatar
mattjk
You can try adjusting the rod under the dash. Try 1/2 turn at a time. you also need to adjust the pedal rest stop if you adjust the rod.
dekarev's Avatar
dekarev
What do you mean the catch point is high?
Before you start worrying about replacing the clutch check the easy stuff.
Check your clutch master cylinder for fluid and check the pedal for free play.
Old May 27, 2013 | 02:00 PM
TEAMxREX's Avatar
TEAMxREX
i do know the fluid is bad..it is black. could it cause it to be that high?
Old May 27, 2013 | 02:01 PM
TEAMxREX's Avatar
TEAMxREX
last owner took trans and motor out a lot could it be adjustment and good as new?
Old May 27, 2013 | 02:02 PM
SC4Paulo's Avatar
SC4Paulo
bleed your clutch master cylinder and if the problem pertains then go look at the other possibilities.
baodalazi
Mar 21, 2011 10:54 AM
pnyboy27
Aug 4, 2008 01:57 AM
LCSC
Mar 28, 2008 04:47 AM
Mr.Machine
Feb 17, 2007 10:09 PM
Lexologist
Nov 15, 2004 03:38 PM
